how much do i trim bump spots with s-techs?
well i'm going with oem bumpstops and dust boot, how much should i trim down the bumpstop for added travel, and do i need to do it for both the rear and front?
thanks guys
thanks guys
My H&R instructions said that only the listed vehicles needed the bumpstops to be cut. My car was not listed. I ended up cutting one notch a little later in the back......
I think the KYBs are actually shorter than the OEM ones, so no cutting should be necessary.
As far as feeling a difference. I did it at the same time I put in Ben's rear shock mounts, so yes there was a very noticeable difference. I think it was mostly becasue of the shock mounts, but the extra clearance I believed helped as well. Before it felt like I was just riding on the bumpstops in the back. That brings up another point, are you planning on using his mounts in the back. I highly recommend them.
I think you will be fine with the KYB bumstops. You can contact Ben at a later time and get those things on there. The back setup is pretty easy to do, and no alignment is needed either. Lower away and show us some shots
What struts are you going to use?
.What struts are you going to use?
so i ended up just ordering kyb boots p/n sb103 and sn108 u guys know that kyb rear dustboot and bumpstop are no longer one piece, its like this tough plastic boot and a urethane bump stop, im confused bc i thought it was suppose to be rubber, could i have gotten the wrong parts? and should i trim this new bumpstop?
REDinLV
Aug 15, 2024 12:30 AM
Need help
23
Oct 2, 2015 08:56 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
