Changing Tranny Fluid?
Old May 2, 2006 | 04:42 PM
GarciaMaxima's Avatar
I didn't see a how to for changing the transmission fluid on a manual 1997 tranny, anybody?
Old May 2, 2006 | 08:39 PM
BlackMaxdout's Avatar
take lower drain plug out, let drain.
replace lower drain plug.
Remove side plug.
Fill with your choice tranny gear oil. (make sure it's 75W-90 API GL-4 ONLY)
*Redline or Amsoil are your best bet.
*takes about 4.5 quarts for manual trannies
Replace side plug.
Old May 3, 2006 | 09:00 AM
By side plug you're mean the plug to re-fill the tranny? I have a manual tranny ,What do I use to remove side plug? What kind of socket
Old May 3, 2006 | 09:51 AM
konak85's Avatar
You have to stick the actual wrench in the slot not a socket for the fill plug on the side. i think its a 1/2 inch drive. BTW there is a how-to in the fluids and lube section.
Old May 3, 2006 | 09:55 AM
Dexter's Avatar
Too much hassle take it to goodyear they'll do it for 50 bucks (at least around here) which is a pretty sweet deal.
Old May 3, 2006 | 10:35 AM
Konak85 is right, the side plug just unscrews by means of a 1/2 square drive. No socket needed. The bottom plug is usually the same way, and if not, it's a big square that you can get an adjustable wrench on.
Old May 3, 2006 | 02:32 PM
thanks guys. I got it now. Here it's around $65-70 to change your tranny fluid.
pktaske
May 6, 2016 07:49 AM
iamute
Sep 20, 2015 05:22 PM
Maxxx10
Sep 13, 2015 03:16 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
