my max has the hiccups
ok i just changed my plugs to iridium and now the max has he hiccups. What it does is that while it idles, it will drop rpm to below idle and back up right away every 5-10 seconds. i have no idea what is causing this . any suggestions. btw plugs are pre gapped so i know it's not the gap.
also does annyone have that problem where you can't get ur idle to hit 750 rpms. mine does 600 rpm and when i try to adjust it slightly it jumps up to 1500rpm. there is no gradual climb. any help would be appreciated . thanks in advance
Have you checked the usual trouble spots? Check your ECU codes; clean the throttle body if you haven't in a while.
TB cleaning really helped my idle and a bad knock sensor code was holding me back also. After I cleaned the KS grounds my ecu was clear and the car's been doing alot better. I also just installed iridiums (NGK) so I assume it's not them.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
