Please Help - 5 SPD swap!
Old May 8, 2006 | 07:53 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
I recently did a 5 Speed Swap, and I got SES (CEL). well the automatic TCM is disconnected, and this sat I swap the ECU and installed a Manual ECU. I still getting two codes P0600, P1605. These codes indicate that, ECU is looking for the automatic tranny. I don’t why I am still getting these codes, Could it be the ECU I got its not Manual ECU? By the way my car year is 99.
Also i am having difficulty going to reverse. I have to Tab the gas couple of times in order to go in reverse. Sometimes I can go to reverse after I try 10 times. Also when I have the car in 2 or 3, or 4th gear when I press the gas, and then let go of the gas i get this kick that comes from the shifter. There is no strange noise in any gears. Only when i have the car in the reverse and backing up i hear this wired noise, that sounds like something is lose (cricking noise) i can't really explain it.
I was told this tranny had 40k on it, and pretty much in a excellent condition.
Can someone tell me what could be wrong?
Thanks In advance.
Old May 8, 2006 | 08:09 PM
WielkiWaac's Avatar
MaximaDriver
i have same problem with tranny codes after 5 spd swap. my car is 10/98 which is called 99.
Old May 8, 2006 | 08:18 PM
CystumMax's Avatar
Mine is 06/98... You don't have any issues going to reverse?
Old May 8, 2006 | 08:21 PM
WielkiWaac's Avatar
MaximaDriver
Originally Posted by CystumMax
Same here mine is 06/98. You don't have any issues going to reverse?
i have problems with shifting all gears. but its clutch problem (thats what i think), on hot days its easier to press it and shift gears, on colder days its harder. i have to make sure there is no air in system and do little adjustment
Old May 8, 2006 | 08:23 PM
mforrest100's Avatar
I had an issue like that. I changed my slave cylinder and it went away.
CystumMax's Avatar
Ok i see, my only problem is going to reverse most of the time, sometimes going to first gear, but not as hard as going to rerverse.
Old May 8, 2006 | 08:24 PM
As for the codes, I think that it may be that the ECU you have is not a 5 Speed ECU.
Old May 8, 2006 | 08:25 PM
Do you have a 99 5 speed ECU?
Old May 8, 2006 | 08:32 PM
WielkiWaac's Avatar
MaximaDriver
still auto, but i need to find out if 5spd 99 ecu will fix my problem.
i was thinking if i unplug tcm everything be ok, but i was wrong
Old May 9, 2006 | 07:40 AM
CystumMax's Avatar
Bump..................................l
Old May 10, 2006 | 03:42 AM
CystumMax's Avatar
Bump>>>>>.............
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
