Exhaust Manifold and Studs
Well I got started on this today finally. Rear manifold was cracked and leaking bad so I had to replace it. Four of the six rear studs were broke. Wow!! what a job..I had to remove y-pipe, stabilizer bar, cat-converter, cross member(one of the rear bolts was a bitc#!),rear motor mount and bracket. I used a jack and a block of wood to support the motor.
Rear flange bolts were rusted beyond recognition, I used impact gun and nut extractors and the studs backed right out of the manifold flange. The cat-conv bolts were even worse..I had to cut them off with a dremel. Front flange bolts were in pretty good shape and they came right off with impact gun. After getting the only two studs that were good out I started on the broken ones. It's not to bad with the motor mount bracket out of the way but it is almost impossible to get both hands up in there. Hardest part is center punching the studs you just cant move once you get your arms up there and if there is a burr on the studd you have to flatten it out or you will never get it center punched.
I managed to get one drilled and extracted before it got dark. I used a 7/64" drill bit and Ampro extractor. My neck was killing me from laying on my back with my head raised up all day so I called it a night. I guess I will spend my Memorial day under my Max.
I see that my power steering lines are in the way of one of the studs so I will have to figure that one out..might have to remove compressor..I will see tomorrow. For now it is Beer O'clock
and the race is on so night all..
yeah, those things are a PITA to do, but they are doable on the car...
one thing I found that helps is to lower the engine down inside the engine bay. since you've got the crossmember and rear mount out, you should be able to lower the engine several inches to increase working room back there.
for the AC lines, you can unbolt the compressor and the mounting brackets on the lines and bend them slightly out of the way without having to actually discharge the system.
thanks for the ideas!!!
Well I got 5 out of six out. I will have to drill and tap the one it just wont come out and I do not want to break the easy out off in it.These studs take a M8x1.25x12.0mm helicoil with a 21/64 drill bit. I will have to track down a kit and drill it out. One other thing..if you take your oil filter and power steering pump off it gives you twice the room. Also if you do not have a right angle drill buy one..it is a must.
For the y pipe to manifold, use only the copper colored the ring gasket, I dunno what the 3 hole gasket is for. Yeah I lowered the engine a few inches when I did my studs, it really helps. GL on the rest..
This is a really big and time consuming job. If you can afford it pay someone to do this!!
Originally Posted by Walka
funny you should say that... what do you guys estimate this repair to be? assume the worst, rear AND front manifold bolts. it finally happened on mine and im at a crossroads. with so much on the car to fix, its time to start thinking about (gulp) putting her down.
.Otherwise bite the bullet like I did and get crankin on her.
Believe it or not, I was able to get my torque wrench on all the nuts to torque them up properly. For the socket, I used a 12mm deep socket. Some had to be accessed from underneath the car.
I had time tnight between thunderstorms to button this up so I put the cat-converter back on and...my max is quiet again!!!
I had to let it run for 15 minutes to burn the PB Blaster smoke off but she is quiet and no tick tick tick...It took me almost 3 days total to do but I saved alot of $$$$ If I did it again it would not take me near as long.
Congrats on getting the job done. I agree, the first time is the worst. When I did it on my second maxima, it took me less than half the time.
I am not looking forward to doing this.
