VQ35 swap questions - near swap date
hey, i have a few questions regarding the swap i'm doing this week.
1. Is it possible to use the Crank position sensor (REF) and use the 3.5 oil pans?
2. There's a coolant tube coming from the bottom of the 3.5. Should I plug that up somehow?
3. Can I use the 3.5 crank pulley? (My 3.0 crank pulley is chipped, and doesnt give the correct readings for the crank ref sensor)
4. If I use the stock accessories on the VQ35, what size belt should I use?
Thanks,
-Freddy
Thanks,
-Freddy
Originally Posted by JClaw
Use the 3.5 sensor. I just cut and soldered the wires. That way a) you don't have to change to 3.0 pan b) you don't have to grind the block for the 3.0 sensor to fit. Your 4th gen ECU will be able to read the 3.5 sensor. Just shaped differently.
Oil cooler or coolant? Either way remove the oil cooler and plug up the coolant line.
Probably. I used a motorstorm UDP for 95-99 and had to grind it some or the sensor would hit the pulley.
The REF sensor is the one by the crank pulley.
Originally Posted by diymaximakid
you can use the 2k2 crank(pos) sensor to keep from grinding anything.just switch the connector for the crank(pos) sensor.
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
QueensMAX
Sep 15, 2015 04:14 AM
