black smoke on start up
Old Jun 2, 2006 | 11:59 AM
risingmist's Avatar
my car has trouble starting up, but once its running it runs like a champ.
at initial start up there is a small puff of black smoke.
Old Jun 2, 2006 | 12:05 PM
z0dE's Avatar
That normally means that your car is burning oil in the cylinders (aka bad). Check the seals on your valves and pistons for cracks or tears if there are any cracks or tears then get them replaced ASAP. The trouble starting could be caused by fouled spark plugs or a faulty starter. My guess is the spark plugs are getting fouled due to the oil getting into the cylinders
Old Jun 2, 2006 | 12:09 PM
risingmist's Avatar
spark plugs looked ok, but i replaced them already.
i changes my clutch, and i just read from another post the it could be a crank sensor on the tranny. so im going to check all that out too.
anyone else got any other ideas?
from what i understood, white smoke is oil, black smoke is fuel, and a light blue smoke is coolant.
i could be wrong though.
Old Jun 2, 2006 | 12:49 PM
itsdaveonline's Avatar
Get new valve guides, new valves, and possibly get new oil controll rings on your pistons Also check that the valve springs are tight, they will probably need a washer added to them soon.
Sounds like a good time to rebuild your engine if you wana...
Old Jun 2, 2006 | 01:03 PM
risingmist's Avatar
anyone else?
i would think the car would somehow be running bad if it needed new valves. like i said, it runs like a champ after the initial start up.
Old Jun 2, 2006 | 01:08 PM
nismology's Avatar
@ some of the suggestions in this thread.
Your car isn't burning oil since oil doesn't produce black smoke, as you already know. Seems like excessive fuel is entering the motor at startup. Maybe the injector o-rings are bad. Any codes?
Old Jun 2, 2006 | 01:26 PM
risingmist's Avatar
got some codes but im at work and cant check them.
Old Jun 2, 2006 | 03:02 PM
RA030726's Avatar
I'm nutty for Nissans
Black is extra fuel being burned AKA rich. All OBD2 cars run rich when cold.
Old Jun 2, 2006 | 03:52 PM
f550maranello2's Avatar
NO black smoke is running too much gas... blue means oil...
Old Jun 2, 2006 | 05:15 PM
drvefastho's Avatar
hmm
blue? black smoke? and why do u guys suggest he change his piston rings, valves and other things as if theyre easily done.
anywho.....valve guide seals.....rubbery.....when the car is cold they allow engine from the heads to leak down into the combustion chamber....as the engine gets warmer the rubber seals expand enough to seal up the gap...therefore u dont get any smoke when ur car is warm....
oil control rings on the pistons could also screw you over in the same way.....i dont know how u would distinguish between the two but i think that if it was the oil rings on the pistons then you could be burning oil all the time..
for the meantime you can try some additive ...Rislone or even Seafoam can help firm up those seals a bit.
Old Jun 2, 2006 | 05:47 PM
willard00's Avatar
cause the rings help stop the oil from getting ontop of the piston and buring so if they are worn and oil is getting up there the oil will burn and create carbon deposits which is not good.
Old Jun 2, 2006 | 06:05 PM
JEXTEL's Avatar
What does white some mean then? If black is fuel and blue is oil.
Old Jun 2, 2006 | 06:22 PM
nismology's Avatar
White is coolant i believe.
Old Jun 2, 2006 | 06:23 PM
nismology's Avatar
This is true. But there won't be black smoke at cold startup with an engine control system that is operating properly.
Old Jun 2, 2006 | 07:06 PM
crazy97's Avatar
You have the dreaded grounding problem
LOOK BELOW!
Old Jun 3, 2006 | 06:05 AM
JEXTEL's Avatar
Ok so im low on coolant?
Old Jun 3, 2006 | 06:43 AM
MaximaInCT203's Avatar
schemes on chicks in his max.
your car is running rich. and you have excessive gas going into your engine....if your not the 1st owner i would def check the fuel pump fuse because some people are cheap to the point where instead of getting new fuses they connect the 2 prongs together with aluminum foil(keeps the fuel pump running even after shutoff believe it or not). or like someone said before you can definitely have bad injector orings
Old Jun 3, 2006 | 06:56 AM
MDeezy's Avatar
Wow. . . from black smoke suggestions were make for valves and valve guide!
You are burning off excessive fuel. If your started is dragging and takes a while to catch and start the engine (let say 6 cranks later) fuel is collecting in there, and finally when the car starts its going to burn off all that fuel shooting out the black smooke in the back.
Our cars naturally run rich at start up in order to get the car up to proper working temperature. and the idle settles down and the car warms up the A/F mixture leans out.
Old Jun 3, 2006 | 10:50 AM
clive's Avatar
100% chingon
Check the ECT sensor is operating correctly.
Old Jun 3, 2006 | 11:13 AM
crazy97's Avatar
He had this happen right after a clutch install. This is definitley a grounding issue. I would bet my right nut. If I am wrong, may I be forced up against a tile wall and violated
Old Jun 4, 2006 | 08:36 AM
Curt's Avatar
I think the guys advocating excessive fuel have it right. That raises the question of whether you have fuel collecting (i.e., dripping) while the engine is shut down (e.g., overnight), or the engine is getting excessive fuel being introduced when you try to start it (bad signal to/from the ECU or a bad injector).
In order to get an idea of which of these areas to troubleshoot further, here's what I'd try: after starting the engine and it's had 10-15 seconds to burn off (or blow out) the excessive fuel, shut the engine off. Wait 30 seconds or so and restart the engine to see if you get that black puff again. If not, I'd suspect that maybe one of the injectors was somehow allowing fuel to get into the port and pool while the engine was off for a long period.
Old Jun 5, 2006 | 07:33 AM
risingmist's Avatar
i think i am recieving a bad signal from the ecu. onc ein a long while when i start it up, the wiper blades swing back and forth about two times.
Old Jun 9, 2006 | 10:57 AM
buntypatel's Avatar
had white smoke once but never black.> Maybe seliniod leak
Old Jun 9, 2006 | 01:38 PM
crazy97's Avatar
http://forums.maxima.org/showthread.php?t=452286
mvm062
Nov 30, 2020 09:00 AM
Maxima.KsA
Sep 8, 2015 11:33 PM
A32goldylocks
Sep 2, 2015 06:39 AM
FlaMark
Aug 21, 2015 11:06 AM
Balkins
Aug 12, 2015 06:39 AM
