Lack of Power after 7500 service What can I tell dealer???
I took my car for it's 7500 mile service, it's a 2K GLE (auto), The moment I hit the highway I felt that something was wrong. She seems to climb through the gear as she accelerated so much smoother., no kick. What really did it for me was her inability to peel tires from a standing start with TCS off. My car just will not do it. What can I tell the dealer?? Is there a torque spec that the car should pass. HELP HELP I want my baby back!!!! /Colin
Best regards,
Fast Walker
I'm running into a similar problem.. one hot day on some nasty bumpy roads something happened to my SE 5speed that has robbed it of quite a bit of power.
I took it into the dealer and told them what I was experiencing.. they did the normal test drive and diag check .. which showed nothing.. since the mechanic wasn't familier with the normal power rate and since it was driving smoothly .. he reported back "no problem found".
I opened a case with Nissan Customer Care and will be taking the car to a dyno this week or next to get some hard numbers. Although.. Nissan won't take any information or advice from outside sources (that was as quoted from Nissan Cust Care).
On a side note.. if anyone has dyno graphs for a stock Max .. please let me know.. so I have as much info for the interesting times to come. bpace@lightning.net
Good luck on your car.. and as silly as it sounds.. did they over fill your oil by a huge margin? They've done that to me a few times at my local dealership.
(BTW.. if anyone has thoughts on my problem.. let me know as well!)
- Bryan
- Bryan
- Bryan
- Bryan
here is kind of a stupid thing to check. I take it you still have the stock intake setup. Look at where the intake scoop attaches t the air box. There is a plastic sleeve holding the two together. If that is loose or slipping off, use some duct tape to make sure it stays in place.
I'm going to check both the exhaust and air intake tracts.. another place I am looking is at the "butterfly" valves in the intake runner. From what I understand the valves close when at idle and open up at higher revs. On startup I see the control pieces acutate.. and then reverse when it gets warm.. but when reving the engine up.. I don't ever see them move over to what I believe is the open position.
I called Courtesy Nissan and got a price on an official Nissan shop manual.. $295! Anyone know of a cheaper place to get it?
- Bryan
- Bryan
lowpost99
Oct 26, 2025 06:53 PM
shilov
Feb 19, 2024 09:40 PM
trungg86
Sep 4, 2015 04:58 AM
Knowing Nissan Service, I doubt that they would have fixed your tranny....but that is wierd....
