5spd swap HELP!!!!
5spd swap HELP!!!!
uhh, . . . . . . . THIS IS MY FRIENDS auto 97 > to 5spd
i did the whole swap, and the car wont start, im getting spark, and fuel,
but it sounds like its firing out of order.
i redid this swap for the 2nd time. i redid everything, double checked everything and still no start, just constant cranking.
it sounds like it really wants to start but isnt.
does anyone know why this is happening? how can the timing get messed up from doing the swap?
i have a 97 auto ecu, a 96 ecu and a 95 ecu ( 95 and 96 are both 5spd)
none of them are working. the crank sensors ( 97 and 96) dont solve the problem either. i done know what to do.
if anyone knows what could be messing this up, plz help.
i checked the grounds, the wiring, spark plugs, coils,
the RPM gauge on the dash ISNT moving at all. thats supposed to do with the crank sensor... right? so i got my volt meter and checked it and its in specks.
uhhhgg!
well if anyone can help plz do
uhhhgg!
Starter bad maybe??? Those things can go at anytime. Does it crank or does it just click, if it clicks then starter is still decent. Check your plugs see if they are greased or oiled over. Did you remember to put fluids in the tranny. clutch engaged, clutch flywheel and tranny all snug together
just some ideas to help out
yep
and yep
how did this get so messed up?
Recheck your connections when you bypassed the park neutral switch or what ever it is called. Did you just bypass it or did you wire it up to the sensor on the clutch pedal? Also check your POS crank sensor.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
