a/c gets warmer under higher rpms why ?
The AC by design shuts off under hard acceleration or high load.
Originally posted by loup1276
do i need to recharge my system under normal driving a/c blows ice cold when i drive harder it gets so warm its like i shut the button off.
All air coming out of the HVAC vents is mixed with the outside air. The moving outside air (when driving) will usually be colder than the air immediately inside the engine bay(when sitting).
colder when driving
The air is colder when driving because the condenser can give off infinitely more heat when 50 mph wind is hitting it than when the two fans are sucking the air through. The more heat is released up front, the more heat the freon can absorb hence colder air. If you'd disconnect the fans, the air would not get cold at all, even on recirc, and even though the compressor is running.
Just running the compressor does not make it cold, it just facilitates the heat transfer, after transfer it must be removed. The moving car does it better.
John
John
tarun900
19
Dec 20, 2021 06:57 PM
Need help
23
Oct 2, 2015 08:56 AM
mclasser
Sep 24, 2015 11:57 PM
Thanks medicsonic and John van de Pol!
