Popping noise in the front suspension
I have replaced front springs and shocks with the Tokico Illuminus and Tokico springs. Since I have done this I have had a popping noise in the front end at very low speeds, ie in and out of the driveway. I thought the ball joints were bad, so I replaced the lower arms, including the bushings. I still get the noise. I checked the sway bar links and they are good. Could this be from the upper strut mounts? I did not replace them because the rubber was in good shape. Any ideas?
Thanks,
neilca
Thanks,
neilca
I'f your getting the popping noise at slow speeds, like in & out of your driveway than it's your swaybar end links! I'f you've changed everything else but those, I suggest you change those also.
I went through this and after changing struts, strut bearings, and everything else (ball joints, etc) it ended up being the rack.
Nobody could find this (This was happening for a year or more) until I went to a shop that did racks.
Changed that out and the suspension is perfect - even though I had changed other parts, nothing made the BIG difference until the rack change.
Powersteering rack. They aren't the cheapest things to replace, I've never done one on a Max, but other cars I've done have been a PITA! Figure a good bit of labor on top of 150-200+ for the part, I'd hate to speculate, but I know you'll want to make sure that it IS without a doubt the rack before you replace it.
FanaticMadMax
Aug 10, 2015 08:55 PM
