Exhaust Problem: irratic idle, and dies when "hot"?
Old Jun 14, 2006 | 02:32 PM
Frakk2000's Avatar
My car makes a bit of a extra humm now, and it comes from just underneeth my transmission:
I think around here, im guessing that is the cat?
But the engine seems to be fine when it is cold, but when I have been driving around a little, it starts to sputter, especially when I drive around in town at low rpm.
Is this cuz of some sensor in the exhaust? Or could I start to look for another source for this problem?
When I let the car cool down for a couple of hours, its fine again, but when I drive around, and set the car in Neutral, you can hear the idle is jitterish.
I don't think the problem is the manifold? I should hear extra noise in the engine compartment then?
Old Jun 14, 2006 | 03:58 PM
Governor's Avatar
O2 sensor is on the Y pipe could be that? do you see any rust around it? also there are two flange gaskets on the ypipe itself that could be leaking or the flex section could have rusted through? you will have to jack her up and take a look.
Old Jun 14, 2006 | 08:21 PM
Sgibb's Avatar
Its prolly the y-pipe flex section
Old Jun 15, 2006 | 04:54 PM
goon9's Avatar
Check coolant level....
Old Jun 15, 2006 | 05:49 PM
Cliff Clavin's Avatar
Way out West
You may have two unrelated problems.
The noise you hear from under the transmission could be a bad flex section (like sqibb said) or the o-rings at the y-pipe or gaskets on the cat might be bad.
As for your idle/stalling problem, you should first check your ECU for codes. If none come up, you have to do some testing and checking. I would probably start with the IACV and TB, along with sensors. A lot of the problems these cars have are with one of the sensors going bad. MAF, o2, coolant temp are frequent problems.
Old Jun 15, 2006 | 10:28 PM
Frakk2000's Avatar
I had the car up and checked, it was some flexitube. Is it hard to fix? Im guessing I need to replace the O2 too?
Or should I just be looking for a complete new y-pipe?
Old Jun 16, 2006 | 05:46 AM
internetautomar's Avatar
mod or sell?
if you were in the US I'd say get a complete performance Y-pipe.
but since you are in norway, you're probably better off just replacing the flex by itself.
Old Jul 11, 2006 | 06:37 PM
kosan's Avatar
I think I have this problem as well but my idling is fine. Sounds like a low buzz.
Old Jul 11, 2006 | 11:08 PM
yay0's Avatar
check your coolant temp sensor. my car had the same problem, when it was cool it ran okay but once it heated up the idle was funky and driving below 3k was sputtering alot. only a $20 part for autozone so doesnt hurt to change it.
Unclejunebug
Apr 2, 2016 05:42 AM
Justin Kroll
Oct 1, 2015 07:03 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
