RSB installation question...
Old Jun 15, 2006 | 01:52 PM
_ck69_'s Avatar
I just received my Progress RSB today (yay!) and read the instructions. It says to jack up the rear end to install. I was told to use ramps as per this tutorial --> http://www.vqpower.com/v2/modules.ph...howpage&pid=12
I unfortunately don't have ramps anymore, so what are the negatives of jacking it up to install?
Old Jun 15, 2006 | 01:57 PM
Stagnet04's Avatar
I did the exact same thing your doing like a month ago, got the progress RSB from the group deal, even used the same link for the install, I installed it with jacks and I don't see or feel anything wrong. I spoke to a couple of local people here to and they all told me it doesn't matter... so I guess it's up to you.
Old Jun 15, 2006 | 02:08 PM
4DRSpeed's Avatar
Project Ruby......
I installed my Progress bar using jackstands, it will be ok all I feel is a dramatic difference in handling. It feels awesome!
Old Jun 15, 2006 | 02:14 PM
_ck69_'s Avatar
Thanks for the info guys. Did you use the grease/lube that was supplied with your Progress bar? Was it enough, or did you have to buy more?
Old Jun 15, 2006 | 02:16 PM
Stagnet04's Avatar
Yes put it on the black bushings(INSIDE THE HOLE ONLY) so they can slide right onto the bar and I guess it will reduce noise in the future....
Old Jun 15, 2006 | 03:31 PM
Radiohead's Avatar
Yes, make sure you grease up the bushings very well to protect them and prevent creaking.
Old Jun 15, 2006 | 07:04 PM
_ck69_'s Avatar
Done! Got the RSB on the car, but with some slight issues.
1. I found that the small pack of grease wasn't enough to properly lube up the bushings.
2. Prying off the ABS snesor bracket from the wire was pretty time consuming. Those clips did not want to move.
3. The instructions said that there should be 1" of space between the end of the bar to the closest bushing. I couldn't get close to 1" because of the e-brake bracket in the way. How did you guys get over that?
Anyhow, it's on there. I guess I'll test it out further tomorrow. Looks good though. Thanks for all your help.
Old Jun 15, 2006 | 08:32 PM
Stagnet04's Avatar
Good questions about the 1". I installed mine just like yours and I read the same thing. I was like at 1/2" inch, thats when I remembered the 2 white ties they put in the box with the RSB. so I went back to adjust it the next day. don't screw the e-brake bracket back on, just slide the clamps over the hole or enough where you have the 1" then you use the ties to hold the line over the clamps and the frame.... but I think it doesn't matter.. Looks good...
Good luck
Excalibur23
Oct 13, 2015 04:33 PM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
