No Reverse Lights
Old Jun 15, 2006 | 08:02 PM
SpeedCrazie's Avatar
No Reverse Lights
I purchased another maxima, and the reverse lights do not work. What would cause this and how can I fix it?
Thanks!
JP
Old Jun 15, 2006 | 09:05 PM
Radiohead's Avatar
Check the bulbs first.
Old Jun 15, 2006 | 09:08 PM
95_Maxima_5spd's Avatar
^^^if the bulbs are ok, check fuses and wiring and make sure all connections are nice -n- tight
Old Jun 15, 2006 | 09:45 PM
Sounbwoy's Avatar
I have the same issue. BUlbs and fuses are OK. I know there's a reverse gear switch on the transmission. Anyone know where? Picture??
Old Jun 16, 2006 | 06:08 AM
97BlackSEGold's Avatar
mine is the same way, they only come on if you hold the stick in a certain place in reverse , if that makes any sense to anyone.
Old Jun 16, 2006 | 06:39 PM
GreenVQ30's Avatar
the sensor is at the back under the car, ince u remove it your transmition oil will leak out, so you gonna have to change tranny oil
Old Jun 16, 2006 | 09:50 PM
whitegold's Avatar
Yup, I just changed the sensor, its the Park/Neutral switch you should be throwing a CEL for that and ignition inhbitor. Except I changed mine and it STILL dosent work ugh
Old Jun 17, 2006 | 07:47 AM
Sounbwoy's Avatar
Is the position relatively the same for MANUAL transmission cars?
Old Jun 17, 2006 | 01:30 PM
whitegold's Avatar
I beleive it is in the same location for manual cars.. not 100% sure.. except your switch is the Neutral/Reverse switch I think.
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
minsbang
Sep 11, 2015 08:48 PM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
