fog light "bulb" to match h.i.d.'s (search no worky)
PIAA Super Plasma H3 Fogs - from housecors seem to be a good match, but does anyone else have any recomendations?
(might do the highbeams too)
thanks for the feedback
nothing will match hids, except hids. the fogs-light housing is very small, and almost no ventilatio in there. any high voltage "bluish" looking bulbs will burn out much faster than oem. the only other bulb i have heard wokrs well is sylvania silverstar. they are pure white, there is no blue coating on the lens at all, and they last. if you like the look of hid fogs, and would replace the piaa if they cracked one or two times, might as well cough up the dough, and buy the plug-and-play hid fog kit from the gd forums.
by the time you replace the fog bulbs a couple of times, you will have spend almost as much time and money as buying the hid kit.
Originally Posted by jeepik
the only perfect match are HID fogs, which is expensive but worth it
the super plasmas match well, but will crack your fog housing eventually
Originally Posted by MxdOut97
the fogs will probably crack regardless of the type of bulbs you have, its only a matter of time. crack fogs will tend to blow more bulbs so if they're cracked you might want to stay with a cheaper bulb, buy new housings, or put laminx or something over the lens.
i have had the HID fogs on for almost a year and no cracks in the housings
umnitza
Sep 1, 2015 01:03 PM
Viralkill
Aug 17, 2015 10:54 AM
