Vibration at 40mph
Old Jun 25, 2006 | 07:54 PM
buntypatel's Avatar
Vibration at 40mph
Really weird but right around 40 mph, my car begins to have a sputter/vibration sound coming from the shocks. would this mean i have to replace the whole shocks? could it be mounts? or is it something else. . it lasts for 2 or 3 seconds until i speed up past 40mph or slow down. but right at 40 its sounds like a quick vibration in the struts. any ideas?
Old Jun 26, 2006 | 02:02 AM
gx2nds4's Avatar
probably the transmission? Not sure I get shuddering at like 25 lasts for like 2 seconds and I'm pretty sure its my tranny
Old Jun 26, 2006 | 05:28 AM
Timothios's Avatar
Usually the tranny. Try to see if it is shifting at the same time it is shuttering. If it is the tranny, probably need a rebuild.
Old Jun 26, 2006 | 05:44 AM
nismos14's Avatar
§è~® f®ÈÄk
UM have you're tires re-balanced. Why do you guys skip the obvious. If this doesn't resolve it then worry about the trans etc.
Old Jun 26, 2006 | 06:51 AM
Timothios's Avatar
He said after 40 mph it stops. My experience with unbalanced tires is that it keeps getting worse the faster you go, but may be worth the try.
Old Jun 26, 2006 | 07:30 AM
nismos14's Avatar
§è~® f®ÈÄk
Everytime I've had bad balance on tires it would be bad at a specific rate of speed then go away past that or below that. Seems a$$backwards of what your used to.
Old Jun 26, 2006 | 07:33 AM
kenju4u's Avatar
he didnt say it stops...he said he starts having vibrations around 40mph.....
Get your tires rebalanced also see if your rims have been damaged cause of a pothole or crack in the rim or something....sometimes its not visible but its there. rotate your tires and see if it gets better...
If all fails then look at something else.
Old Jun 26, 2006 | 07:39 AM
nismos14's Avatar
§è~® f®ÈÄk
Yes he did, re-read it.
Old Jun 26, 2006 | 07:50 AM
Timothios's Avatar
read slowly and carefully :
user 11122324
42
Jul 18, 2022 03:35 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
06maxima55
Sep 28, 2015 04:29 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
