Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
"Wet sanding" on old paint job
Old Jun 29, 2006 | 04:58 PM
Taxvictim's Avatar
I don't understand the concept of wet sanding. Sounds like you take some 2000 grit sandpaper or better, soak it in water, keep the car wet, and just sand away on the paint finish?
My mother-in-law's old maroon Toyota looks pretty nasty, so I thought I'd take a shot at it. Hand application only. Should I try wet sanding the finish to get rid of years of paint contamination?
Old Jun 29, 2006 | 07:04 PM
KeithD's Avatar
You have to buff heavily after wetsanding, and it's quite easy to mangle a paint job. Try just claying, buffing, and polishing, i imagine you'll get the results you're after.
Old Jun 29, 2006 | 09:43 PM
max723's Avatar
is this the same as color sanding? just wondering.
Old Jun 30, 2006 | 09:53 AM
Taxvictim's Avatar
Buff, as in machine buff?
Old Jun 30, 2006 | 09:56 AM
Jeff92se's Avatar
I'm needing a caw
If you don't know what's needed or what you are doing, wetsanding is a good way to 1) ruin the pain job and 2) create a TON of new work.
A) Evaluate how bad the paint is.
B) Determine the least abrasive method of getting the shine back
But if the clear is all worn off, nothing will bring the shine back (if it's a metallic base)
I'd do a ton of reading and searching before laying a finger on her car.
Old Jun 30, 2006 | 09:58 AM
Taxvictim's Avatar
Okay, sounds like I'll stick with clay, paint cleaner, polish, glaze, and sealant. Thanks.
Edited to add: I did test rubbing compound on part of her car, but it didn't seem to make much of a difference. The Maguiars paint cleaner did help a lot.
Old Jun 30, 2006 | 12:06 PM
PrinzII's Avatar
OG and counting...
What grade of rubbing compound did you use? If you used a light one, I could see you not getting results.
Also, are you doing this by hand or machine? For heavily oxidized finishes, I would break out either my PC or rotary.
Old Jun 30, 2006 | 12:15 PM
Taxvictim's Avatar
Doing this by hand.
I think the rubbing compound was by Turtle Wax. They had "rubbing compound" and "polishing compound" next to each other, each in the same sized container. The grit in the rubbing compound was very noticeable.
In the days before clearcoat, rubbing compound was a good way to move paint over a scratch to hide it. My rag would have the car's paint color on it when I was done. Now, the rag just has the compound on it. Don't think I'm really getting down into the color paint itself.
Old Jun 30, 2006 | 12:16 PM
PrinzII's Avatar
OG and counting...
Correct. Most modern vehicles are basecoat/clearcoat. There are some Lexus paints that are still single stage.
Old Jun 30, 2006 | 12:18 PM
Taxvictim's Avatar
PrinzII, your gf's Dodge Neon looked great!
Old Jun 30, 2006 | 12:21 PM
PrinzII's Avatar
OG and counting...
Thx. The challenge is going to be teaching her how to keep it up since she is not accustomed to doing that sort of thing.
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
doctorpullit
Mar 29, 2016 11:08 AM
