exhaust leak = less power??
Originally Posted by Fr33way
I would think that a leak would cause turbulence which would slow the exhaust stream velocity. A leak before an O2 sensor could cause altered readings and screw with your a/f ration.
You don't lose any open loop power since the ECU ignores the o2 sensors then anyway. You'll just lose power during light acceleration and your MPG while cruising will suffer dramatically.
Originally Posted by mazzivart
The ECu will not "ignore" the o2 sensors b/c that would be the same as not having any 02 sensors
nismology is a sick bastard, he sleeps with his FSM
nismology > you
The ECu will not "ignore" the o2 sensors b/c that would be the same as not having any 02 sensors and my car didnt want to run when I forgot to put one back in when I was looking at my exhaust to make a lay out plan for putting my y-pipe I am getting in. O2 sensors control A/F ratios and make the car go. The ECU will not bi-pass them.
which reminds me... I have to get that fixed!!
thats a load of crap.. ill explain it so everybody can understand... when u first turn ur car on in the morining for example the ecu will ignores values from the o2 sensors just untill the car gets warmed up..... same thing if u floor it the values are neglected...
i got bills, how bout i sell you a clue
lowpost99
Oct 26, 2025 06:53 PM
Hdnseek
Sep 9, 2015 05:55 AM
... from the guys at cartalk.
