WTF!!!! P0400.. 0302 code again.!?!?!?!
Old Jul 10, 2006 | 11:16 AM
f550maranello2's Avatar
Alright im really getting sick of this.... im throwing a code for egr flow malfunction (low flow detected) i cant figure this damn thing out.... t
this is what i have done already
cleaned entire egr system
checked egr valve for leakage
checked egr for movement (moves freely)
checked the egr solenoid thing...(it works)
checked the egr bpt valve thing (workes fine)
What the h.ell could be the problem here........
Old Jul 10, 2006 | 12:46 PM
stglock's Avatar
I went thru this issue myself lately. If you look at the IAC port and to right of it, there is a pipe with an EGR temperature sensor with it. You must remove this pipe (there are 2 bolts at the top and 2 bolts at the bottom) and clean it. Mine was plugged with carbon!!
Once you have cleaned this, you then have to reset your ECU.
-stglock
Old Jul 10, 2006 | 02:36 PM
95jr6708's Avatar
I have the same problem as all of you...thanks for the info ^. I wil try that tommorow. I even changed my egr valve which was a b**** and expensive. so hopefully its just the tube...
Old Jul 10, 2006 | 02:56 PM
already did... it was almost soild when i cleaned it.. didnt help a bit.... anybody else....
Old Jul 10, 2006 | 06:15 PM
come on night crew.... help a brother out....
Old Jul 10, 2006 | 06:25 PM
matty's Avatar
Passage blocked as per the FSM for P0400
Old Jul 10, 2006 | 06:28 PM
yea i know but where??? i removed the entire thing and cleaned it...
meaning the
egr tube.. egr.. the egr hose that is bent all that s.hit
Old Jul 11, 2006 | 10:15 AM
knight71's Avatar
I don't know bro!.maybe this might help...good luck!
http://img52.photobucket.com/albums/v158/evilBIGD/EGR/
Old Jul 11, 2006 | 10:24 AM
JPMax's Avatar
What's next!?..
I'm in the same boat. Just haven't had time to do anything about it yet.
Just a thought..
I believe the EGR code can also be caused by an exhaust leak.
I know for a fact that the flex section on my Y pipe has a small leak. Mechanic showed it to me 2 months ago. A week later the code came up.
I guess I'll see about getting that fixed first.
Old Jul 11, 2006 | 10:35 AM
alright i just removed the entire... i mean entire egr system.. its f.ucken clean!!!!! and all the hoses are in good shape
Old Jul 11, 2006 | 11:13 AM
Sounbwoy's Avatar
550- there is a SMALL pipe that connects the EGR valve to the BPT valve.
Here is a picture-look where the red circle is: http://target.pg.photos.yahoo.com/ph...nm=ed24re2.jpg
The ONLY thing that connects that pipe between both valves is a piece of hose. As you can see from the picture, mine is completely BLOCKING the pipe, because of age. Make SURE that hose is in good shape. I just bought a piece from the parts store and replaced it. MAKE SURE THAT pipe isn't CLOGGED either!!!
Feel free to look at all the other pictures I took when I did mine. They are here:
http://target.pg.photos.yahoo.com/ph.../ph//my_photos
The thread I started when I did mine is here:
http://forums.maxima.org/showthread.php?t=470051
I would strongly recommend checking that pipe tho. I forget right now what year your car is. I have a 1996 SE.
Old Jul 15, 2006 | 10:33 AM
Sounbwoy's Avatar
Hey 550. Did you ever get the EGR system working without any CEL's coming back? Tell us what you found!
Old Oct 23, 2009 | 06:05 PM
♥cece*oaks♥'s Avatar
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
