trunk tension rod replacement
Old Jul 13, 2006 | 07:03 PM
ChromeSE5's Avatar
Anyone know how to put these back on? I think the FSM has a special tool but any help would be appreciated. Thanks. BTW, is there also anyway to adjust the spring up of the trunk (I am now spoilerless and the trunk seems to fly up fast). Thanks
Old Jul 13, 2006 | 07:41 PM
GigEmAgs07's Avatar
good question about the 'spring-up-ness' of the trunk. My trunk doesn't spring up at all, i just hear the click and then have to lift it the whole way up. I have a spoiler, maybe the weight of it just keeps it down. Anyone know of a way to get it to pop up a bit on its own?
Old Jul 13, 2006 | 08:13 PM
ryant35's Avatar
Mime springs up half way, I would like it to spring all the way open.
Old Jul 13, 2006 | 08:23 PM
SilverMX's Avatar
Wow, shows what I'm used too. I too have a spoiler...it doesn't come up at all just unlatches then i manually pull it up. Hell if there is a way to adjust or correct this let me know...I'll investigate myself when I have the time. I leave for Key West tommorrow for 2 weeks.
Chrome...I'm interested in the stillen RSB but as you can see do not have 15 posts or more to PM you with... I will soon though. E-mail your price if you please, maybe some photos of it's condition. Thanks.
Old Jul 13, 2006 | 09:31 PM
MIXXMAX's Avatar
If your Max came equipped with a spoiler, and then you remove it...then the trunk will fly up more. This is because the torsion bars will now have to be swapped out. You must replace it with the torsion bars that came with the Max's without the spoiler installed. The difference between the two is just what it is....torsion bars with spoiler (supports additional weight given on trunk with spoiler attached=soft closing of trunk; no hard slamming from additional weight put on trunk from spoiler) and torsion bars without spoiler (gives normal trunk weight without the added weight from spoiler=nomal,soft closing of trunk with just the trunk weight with no additional weight added to it, such as a spoiler). All Nissan spoiler kits come with replacement torsion bars because of the added weight to the trunk. So, I wouldn't find it possible if any adjustment would be helpful for the bars that you have in there. I would just try to swap for the other one that you need (maybe, at a local junkyard?) Good luck!
Old Jul 13, 2006 | 10:23 PM
ChromeSE5's Avatar
thats what i figured. Now is there a tool to install them?
Old Jul 17, 2006 | 11:01 AM
BLK2BLU's Avatar
What about replacing them with some type of pneumatic shock?
Old Jul 17, 2006 | 12:54 PM
Jamesrc's Avatar
As far as a tool I've always used long needle nose vise-crips. I don't belive there is a tool for it. BE VERY CARFUL, those things can f*** you up if your not.
Old Jul 17, 2006 | 01:43 PM
ryant35's Avatar
There's a mod in the 4th gen forum for this, it uses a hood strut.
I'm not sure that the range of the shock allows it to open all of the way.
Old Jul 17, 2006 | 03:04 PM
BLK2BLU's Avatar
Is there anything for the 5th gen?
Old Jul 17, 2006 | 04:42 PM
ryant35's Avatar
I'm pretty sure the trunk hinges are similar if not the same.
Old Jul 17, 2006 | 06:07 PM
djfrestyl's Avatar
Suspension Yoda
4th and 5th gen are similar and you can use replacement struts to do the same task.
Old Jul 17, 2006 | 08:05 PM
ColdSHO's Avatar
what about those running cf trunks, what are all of u guys using, is it light enough that u wouldnt even need any kind of pretension
Old Jul 17, 2006 | 08:10 PM
A33 VQ30DEK's Avatar
too much tension. It will fly right open
Old Jul 18, 2006 | 09:03 AM
CVicVogel's Avatar
Question
I had the spoiler put on by the stealer...and there was no mention of switching out the torsion bars.
I would love to find out how much and how hard they are to put in.
My trunk slams shut way too easy.
thanks
Old Jul 18, 2006 | 09:16 AM
MaxBoost925's Avatar
Drug Money
I'd like to know how to remove it as well.
Old Jul 18, 2006 | 09:28 AM
djfrestyl's Avatar
Suspension Yoda
If you're replacing the old ones with new ones, just use a grinder or bolt cutter to snip these off. Getting the new ones on is a different story, and I don't have any info about that.
Old Jul 18, 2006 | 09:32 AM
Drug Money
theres TENSION in it! You will be if you snip it
Old Jul 18, 2006 | 09:44 AM
djfrestyl's Avatar
Suspension Yoda
In the middle? Just to cut it in half?
Old Jul 18, 2006 | 09:56 AM
Drug Money
When i open the trunk it looks like theres tension in it. So if you snip it, I believe it will fly apart.
Old Jul 18, 2006 | 12:13 PM
ChromeSE5's Avatar
fcker flies off. I used a large monkey wrench a lot of leverage. Getting it back on is being a pain the ****.
Old Jul 18, 2006 | 12:19 PM
Drug Money
how did you get that fcker off? :
Old Jul 18, 2006 | 12:25 PM
ChromeSE5's Avatar
lol good point... ill take pics later.
Old Jul 18, 2006 | 07:30 PM
BewstAdd1ct's Avatar
use a deep socket with an extension attached to it.
the socket goes over the end of the bar and you can apply tension to it.
Old Jul 18, 2006 | 07:31 PM
here, this might help
Old Jul 19, 2006 | 12:18 AM
Drug Money
I havn't actually checked the tension bar itself because I can't. The Maxipad is in the body shop .
So there are how many bolts holding the bar? And where?
Old Jul 19, 2006 | 06:14 PM
i didnt see any bolts, but i didnt look. usually, theyre held in just by tension, sometimes a guide is in place.
Old Jul 19, 2006 | 11:07 PM
Drug Money
As far as I remember I think there was a white piece on the middle of the bar that kinda holds it in place and there are 2 places on either end where the bar hooks around.
...So to the point - how do you remove it?
Old Jul 20, 2006 | 03:31 PM
remove the bar with the loose end from the groove, at this point, the bar might snap out of place, so be careful.
the trunk also might fall, or drop slowly.
also note, ive done this on several cars, but not a maxima yet, so im basing this on non-specific experience.
good luck
Old Jul 21, 2006 | 08:10 AM
Jamesrc's Avatar
Dose no one read anything I write, I'm an "out of work" nissan tech and have done this on several ocations installing spoilers on new cars. Lay in trunk, put leg up to keep trunk from slaming on your legs. Grap the end of the bar that dosent go into the hing w/ long needle nose vise grips and rotate it out of the mount. then do the same thing to the other bar. Don't cut them thy are under a good bit of tension so they would most likely fly out and hit you in the face.
Old Jul 23, 2006 | 12:13 PM
basically what he said, except a deep socket and extension works much better than pliers.
and yes, they will fk you up, and so will the trunk if it falls on you.
lowpost99
Oct 26, 2025 06:53 PM
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
Hailstatejig
Sep 2, 2015 06:52 AM
