help, 92gxe to 89se
Old Jul 18, 2006 | 07:56 AM
grinder's Avatar
help, 92gxe to 89se
I am currently swaping motors from a 92 gxe to a 89 se and i need a little info. The axles from the 89 look bad and the 92's axles are new, would they interchange? the 92 is auto and the 89 is 5spd, would that effect the swap? Also I wante to know what the easiest way to take the pass side axle from the motor is. I had alot of problems with it when it took it out of the 89 and don't want to go through that again with the 92.
Old Jul 18, 2006 | 09:57 AM
Greeny's Avatar
¯\(°_o)/¯
The axles are the same unless one of your cars has abs...
Refer to the repair information sticky for info on the axle removal..And other repair info as well..
Old Jul 18, 2006 | 10:00 AM
grinder's Avatar
thanks, I don't think eather one has abs so i hope it is a clean swap
Old Jul 19, 2006 | 04:21 AM
internetautomar's Avatar
mod or sell?
you can use an ABS axle on a non-ABS car without a problem
Old Jul 19, 2006 | 05:11 AM
Greeny's Avatar
¯\(°_o)/¯
I've heard this could be done,IIRC you just need to take the abs sensor ring off..
Old Jul 19, 2006 | 06:40 AM
Alex_V
dont even have to do that. Mines got one or two abs axles and it does its job.
~Alex
Old Jul 19, 2006 | 08:23 AM
grinder's Avatar
so the axles will interchange without any problem abs or no abs.
also, when i bought the 89, the radiator mounting bolts were broke off, one is flush and the other is sticking up a little, what would be the easiest way for me to get those bolts out?
Old Jul 19, 2006 | 08:55 AM
Greeny's Avatar
¯\(°_o)/¯
All depends if they are rusted in there...If they are then you might be able to just drill the bolt out,then put slightly larger bolt in it's place..
If they are not rusted too bad,center punch the middle of the bolt,then use a bolt extractor[commonly referred to as "easy outs"] to remove the rest of the bolt...
Old Jul 19, 2006 | 11:39 AM
Alex_V
Get some PB blaster and soak the bolt that sticks up a little, then use some vice grips, and clamp them down as tight as possible. for the other, see if some is sticking out the bottom but its probably easier to center punch and extract.
But the best thing to do is always have PB blaster on hand and use it on any bolt your about to take out, its my #1 rule. I broke it the other day and the same thing happened to my rad mount screws too.
EDIT- also if you need anything LMK, I live in columbus so if you need help with big stuff I can help. Theres also 6 maximas in the local pick n pull, 4 3rd gens and 2 4th gens, so theres plenty of parts near me if you need anything.
~Alex
Old Jul 19, 2006 | 05:54 PM
grinder's Avatar
~Alex
Yeah i've already used one can of pb and only have one motor out so far. I will let you know if i need any thing and thanks for the offer.
CapedCadaver
19
Jul 7, 2008 02:11 PM
simplykc
Dec 3, 2004 08:55 AM
JESSE93SE
May 28, 2004 02:41 PM
septimus
18
Dec 1, 2003 02:46 PM
matt92gxe
Dec 15, 2000 07:37 PM
