18x9 offset question help for TSW Vortex.
Old Aug 1, 2006 | 04:38 PM
ryanvalin's Avatar
I"m going to run a staggered setup on my TSW wheels, which I am about to order, but I have a few questions for the pros.
The fronts will be 18x8's with a 40mm offest (I'll probably run 10mm spacers to get them flush with the edge of the car) and 235/40's.
I am going to run 18x9's in the rear with 265/35's, and their only options for offset TSW gives is a 20 offset, and 35 offset. Which ones should I choose? I don't mind being in too far, as I can run spacers.
Am I correct when I say that the larger the offset, the further they stick in towards the center of the car?
Old Aug 1, 2006 | 04:57 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by ryanvalin
and 235/40's.
IMO, use 245-40's
http://marksink.com/tire_wheel_offset/offset.html
The rears @ +35mm will stick out 35mm and be 15mm closer to the strut housing.
Old Aug 1, 2006 | 05:09 PM
ryanvalin's Avatar
at 35mm will they stick out from the car? That is the question.
Old Aug 1, 2006 | 06:14 PM
NmexMAX's Avatar
dot dot dot ...
Measure them from the stocks.. Only way to find out.
Old Aug 3, 2006 | 12:03 PM
Larrio Motors's Avatar
Boss Chen Industries
Ideally 38mm would be optimal for the rear
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
