RPMs...
Old Aug 7, 2006 | 07:13 AM
lilmyth's Avatar
RPMs...
Guys,
I hope I'm dreaming here, but, for some reason I'm thinking my car is reving too high when cruising. If I remember correctly, when I use to drive at a normal 55 - 65 mph, my rpms would be under 2. However, here recently, it seems that during normal driving,(55 - 65 mph), my rpms are above 2.
Any thoughts on why this might be happening? I noticed this because I am filling up more often.
Thanks!!!
Old Aug 7, 2006 | 07:35 AM
kamski's Avatar
.org extraordinaire
Originally Posted by lilmyth
Guys,
Thanks!!!
Your not dreaming, you have lost your mind. I'm at 2200rpm at about 60mph/100kmh.
Kamski
Old Aug 7, 2006 | 07:36 AM
NismoMax80's Avatar
SuPeRmOd
what is an "rmps"???
Rotations Per Minutes???
well my RPM are at 2500 at 70mph. 2000 RPM is close to 60. now there will be a slight RPM difference between coasting at those speeds w/o pressing the pedal and maintaining those speed by using the gas.
Old Aug 7, 2006 | 08:56 AM
SilverMax_04's Avatar
In my 04 with the 6-speed manual in 6th gear, I get the following:
55 MPH = 2,000 RPM
82 MPH = 3,000 RPM
These are the two that I remember off the top of my head. Midway between these two reading would be 2.5 K RPM and that would occur at about 68 MPH.
You will have slightly different results with an auto-trannie when the engine is pulling (not coasting -- per Nismo above). However, your results will not be greatly different from mine and certainly not below 2 K RPM when going over 60 MPH.
My previous car (98 Olds Intrigue with 3.8 L engine) would do what you describe: at about 2 K RPM the Olds was doing about 66 MPH. This slower engine speed was why this car would normally get between 30 and 32 mpg on the interstate, while my Max gets between 28 and 30 mph on the same drives. But my Max does not struggle in top gear when I drive to Denver on
I 25 over Monument Hill because of its lower ratio gearing.
Old Aug 7, 2006 | 09:48 AM
!PrjctMax!'s Avatar
The 5spd auto in tiptronic mode shifts into 4th at 97mph! lol please don't ban me
Old Aug 7, 2006 | 09:58 AM
That would mean that in 4th gear the VQ's RPMs at 97 MPH are red-line = 6,500 RPM. But 4th gear is not top gear, which was the original question.
Old Aug 7, 2006 | 10:12 AM
gurlie_J_gurl's Avatar
I wanna be at my maximum
for me on the highway w/ the cruise set (automatic)....80mph is just below 3k rpm
Old Aug 7, 2006 | 10:40 AM
lfc.reds's Avatar
5th gear auto on freeway, 2750RPM is about 85MPH.
55-65MPH is around 2000RPM.
Unless you are accelerating, RPM does not change for the same gear travel at the same constant speed.
Old Aug 7, 2006 | 11:43 AM
lilmyth's Avatar
Thanks all... I feel better.. Ha...
Kawowski
24
Jan 9, 2017 09:13 PM
Juanurbinapr
Apr 28, 2014 07:52 AM
allthatisman
Apr 10, 2012 10:09 AM
maxima dude
23
Aug 4, 2011 11:03 AM
Grand_hustle17
149
Apr 3, 2011 04:55 PM
