Low fuel vol. reading on obd II after header/y install
Low fuel vol. reading on obd II after header/y install. has anyone else encountered this?
Pressure is good, volume I am low.
you are too lean, all these mods lean out the car, you need a piggy back or the ecu done..
lean: too much air and not enough fuel..
the guy at TS, doesn't run fuel REG's, you don't need that, just some fuel added by terms of piggy back or ecu..
I wouldn't run it like that for long, get it done quickly..
Neo
Getting neo installed, and getting a roller run mon, tue, or wed.
.. so I can send maps w/ ecu to TS, and to (hopefully) cure fuel problem.
BTW car is parked, not driving it that way at all
.. so I can send maps w/ ecu to TS, and to (hopefully) cure fuel problem.BTW car is parked, not driving it that way at all
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
