in the market for a new set of wheels/tires
Well,
After balancing, and rotating the wheels, got the alignment done to the car, and balancing the wheels again i came to the conclusion that these wheels are just not gonna do it for my car.
The vibration is not as bad as before but it's still there.
I thought it was actually the car but with the original 17's (O.E.M. wheels) there's ZERO vibration.
I wonder what could it be? My mechanic inspected the wheels and balanced them twice. He even place the weights inside and outside the rims and assured me this time they were truly balanced. The wheels suck! Or could it be the cheap kumho tires?
Wheels are BSA (I know they are cheap)
Any feedback will be appreciated
here's what you do go back to the place you bought the wheels and tires. tell them you want to road force test them. what this does is tell the tech if the wheel and or tire are out of round. if they are out of round they should have no problem replacing them under some kind of warranty. btw i;ve seen alot of problems with kumho tires being out of round and having excessive road force
Originally Posted by i30ds
Can't go wrong with Rays Engineering 57C 17X7.5 GramLights and Yokohama AVS 235/45 R17 tires.
I took the car back to my mechanic and he noticed they forgot to install the hub-centering rings. DUh!
Problem fixed!
Wheels are loooking weird with the weights in the inside and outside of the wheel (lip) but hey, the steering wheel does not vibrate anymore.
I think I'm gonna sell these and buy the g35 18" wheels. Mmm.....
Problem fixed!
Problem fixed!
Problem fixed!
I'm suprised they even fit on in the first place with out the hubcentric rings.
True... but I had a set of rims that required hub centric rings and they would not fit on properly with out it... It was pretty obvious. As soon as the ring was on the rim or hub they slid on with ease. Of course I never tried to forcefully install them with out the rings but this guy's mechanic must have had a severe mental lapse to install all 4 wheels with out the rings.
Can you fit staggered wheels in the i35 without the back tires rubbing?
I wanna get like 19x8 (front) and 19x9 (back) but I'm not sure if it will fit or if it will rub.
Might want to PM him.
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
