clicky sound
Old Aug 13, 2006 | 12:04 AM
Superman's Avatar
clicky sound
recently i notice my 01 max started making this clicky sound when i'm driving under 30 mph. it sounds like click click click click click click........i think it's coming from the rear. recently had the rear brakes and new muffler done, would the wheel bearings make that sound? what could it be?\
thanks
Old Aug 13, 2006 | 12:36 AM
MaxBoost925's Avatar
Drug Money
It could well be your axles.
Old Aug 13, 2006 | 08:13 AM
97Se5spd's Avatar
Maybe low oil?????
Old Aug 13, 2006 | 08:32 AM
AceofSpds's Avatar
wat
Are your lugnuts tight?
Old Aug 13, 2006 | 01:04 PM
Max2K2's Avatar
Check your rear tires for a screw, nail, or a rock stuck in the tread.
Old Aug 17, 2006 | 03:40 PM
four's Avatar
maybe your rear brake hardware kit isn't installed properly. that happened to me before.
Old Aug 17, 2006 | 04:18 PM
Yayomax's Avatar
still brewin'
if its a steady click that increases with speed, where ever end you hear the noise to be coming from, try jacking up that end of the vehicle and obviously secure it on jackstands and try spinning the suspect tires to see if it repeats itself. Or simply, as was previously mentioned, inspect your tires for foreign objects. If its an intermittent click, check for loose hardware in the aforementioned parts that were serviced.
Old Aug 17, 2006 | 04:20 PM
Yayomax's Avatar
still brewin'
if its a steady click that increases with speed, where ever end you hear the noise to be coming from, try jacking up that end of the vehicle and obviously secure it on jackstands and try spinning the suspect tires to see if it repeats itself. Or simply, as was previously mentioned, inspect your tires for foreign objects. If its an intermittent click, check for loose hardware in the aforementioned parts that were serviced. I was told numerous times that wheel bearing don't make a click sound but rather a grinding/howling sound
Mahmuth
Aug 16, 2024 08:23 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
