Has Thing Happen Too You????
Old Aug 13, 2006 | 10:35 PM
BUSi87's Avatar
Hey, well about a two weeks ago my fuse for my fog lights blew....well finally yesturday i came around to buying some fuses and well when i went to put the fog light fuse my fogs worked perfectly but my right side blinker front and rear stay lite too. I messed wit all the fuses that have to do with all the cars lights. I can't figure it out. Can anyone help me out??? Can it be that i might have some wires touching or a bad relay??
Old Aug 14, 2006 | 04:25 AM
9DTALON's Avatar
Something is grounding out and the current is making its way to the blinker lights' circuit. You're going to need at least a test light and a good wiring diagram for the circuit and start testing. But to make things easy on yourself just take it to the dealer. You'll only end up paying labor since they will likely just fix the wire.
Old Aug 14, 2006 | 04:30 AM
geenowalker's Avatar
Sounds like either your turn signal switch or the signal flasher is dead. The flasher is sometimes located in the fuse panel and is relatively cheap.
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
msellas
Sep 23, 2015 09:16 PM
ColdCananda
Sep 20, 2015 10:45 PM
