New Clutch INNNNNN!!!!
Well finally got the new clutch in. Clutchnet 6puk spuring hub, and the red pressure plate. Drove the car to work and wow it just feels nice. The Shifter is stiffer going into each gear which I actually like, and the engament point compared to the Spec stage 3 is so much lower. The car feels like it just wants to run away when I gas it a little. How many miles do I have to break it in for before I go all out. I havent boosted in about 4 months due to various problems and im really itching to press the pedal. Btw I also put a new oem flywheel in along with the clutch.
Heres a hint, in 6 months i replaced my clutch twice with a spec stage3, they are bad and dont hold the power, now i dont know what your making, but for me, it was a big no no.
Originally Posted by sean05
quick question.. how long will a spec stage 1 hold up on 10psi
spec stage 1 is worse than stock. The stage 2 would hold ok on 10psi if you didn't abuse it by slipping it alot, but its not enough clutch really.
Originally Posted by noreaga0221
I haven't seen you on phillydsm so I was wondering where ya went!
I cashed out of dsm's and i'm looking for a 2k-2k1 currently.
Congrats on getting the clutch in and I hope you get those bugs worked out.
I broke mine in for about 800 miles. I had zero chatter for the first few 100 miles and after it started to get gripper and it developed some chatter. The chatter is not too bad and it might not be there at all if I didnt have solid mounts.
I eventually got a little chatter but I never paid any attention to it or what rpm I was at when I launched. It didn't happen often, I do however get a humming noise upon lauching soft. Im still driving on mine with a stock car
Originally Posted by PharoNDmist
I know I get some chatter when I try to slip the clutch from idle. Im so used to reving it to about 1400rpms I hardly even notice it.
You still getting chatter ?? Explain your chatter if you are ? I put about a mile on my clutch, cant really drive it till I get the fans working, and Its chattering bad in my driveway
-matt
-matt
I got chatter on the Clutchnet Red + 6-puck until about 1500 miles, then it slowly faded. I do hear a metal on metal groan on cold mornings sometimes when backing out of the driveway - but it's very very minimal.
Now, I can't get it to chatter if I try it seems. I've had the clutchnet for 20k now and through 2 trannies. It grabs like the day I installed it. Great clutch.
Why two trannies ?? As I see it, the Clutchnet isnt as hard on the trans as say the ACT was on my old trans. Its a softer PP therfore less harshness on the trans ?? kinda right ?
-matt
-matt
-matt
-matt
Actually, the first tranny I bought for my 5spd conversion with 125k miles on it and had an ACT clutch that exploded in it. A few months later, bearings inside it went. I then went VLSD and Clutchnet - that tranny is holding up fine as is the Clutchnet.
You'll also notice that the clutch below, the ACT "Stage 1" disc - only has 4 springs (should have 6) - that's because the people that sold me the clutch shipped me one for a SENTRA and didn't tell me. The receipt even said "95-99 Nissan Maxima, ACT Stage 1 Disc".
Held up OK for almost a year....then one run at the track on slicks......poof!
My guess would be:
a) They have to fit them all into a fairly small place, as there are 6.
b) Covered so they don't pop out?
Seriously - I don't know - but I see what you mean, as illustrated in the pic below.
I just gotta get these fans working and then I can get some miles on this clutch. I hope it stops chattering a bit.
Keep it Under 55mph and Under 3000 rpms for 800-1000 miles, Correct ??
-matt
-matt
Clutch recommendation
Can anyone make a good recommendation for a good racing clutch for a 2000 SE? I am currently using a NISMO stage 1, and must say that my stock clutch was much better than the NISMO. Please help because I think that my NISMO might be getting ready to go anyday now.
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
carlosvq30
Sep 26, 2015 09:44 AM
