NGK Plugs....Plats or Copper?
Old Aug 16, 2006 | 04:22 PM
progrocker's Avatar
I just threw a new set of ngk plats in the max. I know the plats last longer but I'm hearing the coppers give a better spark.
Just an informal poll to see what y'all are using.
Old Aug 16, 2006 | 05:02 PM
nathan91tt300zx's Avatar
Plats are the way to go. You won't see any measurable gains from copper.
-Nate
Old Aug 16, 2006 | 05:34 PM
nitink's Avatar
last sunday I replaced platinums with copper one in my 95 GLE.
copper were cheaper and anyway I like to change plugs once a yr or so,
I didn't feel any difference so not sure about gains etc,
Old Aug 16, 2006 | 06:44 PM
chicken-n-rice's Avatar
platinum or irridiums. Coppers will not last as long as platinums or irridiums and you may not get peak performance or gas mileage out of them, I belive the oreiginal plug was a platinum, so you should at least stick with what came from the factory.
Old Aug 16, 2006 | 06:46 PM
adithius's Avatar
I use copper. Seems the same as plats, but a lot cheaper.
Old Aug 16, 2006 | 08:28 PM
99grnmaxgxe's Avatar
OEM FTW.
Old Aug 17, 2006 | 06:11 PM
96i30azn's Avatar
I would go with Iridium, sparks better than plats, lasts longer(120k vs 100k). and throw in that its also cheaper and you have the winner.
Old Aug 17, 2006 | 06:19 PM
kcryan's Avatar
Copper =$12
plat=$75
Copper=30k
Plat=60k
Coppers worth it for me, better spark supposedly too
FunLovinMaxima's Avatar
From: a charming town in Connecticut first settled in the 1600s
http://maxmods.dyndns.org/index.php?MaximaSparkPlugs
Old Aug 17, 2006 | 07:47 PM
progrocker's Avatar
Originally Posted by kcryan
Copper =$12
plat=$75
Copper=30k
Plat=60k
Really? $75....I just picked up 6 ngk plats at advance auto for 3 bucks each.
Old Aug 17, 2006 | 07:50 PM
Nissan 6's Avatar
They werent platinums then.
Old Aug 17, 2006 | 07:51 PM
kcryan's Avatar
Nope not plats, unless they were a terrible company, in which case ur just fcuked....
Old Aug 17, 2006 | 08:05 PM
cam_honestiam's Avatar
Myth: Copper = Better Spark
Copper will not give you as hot of a spark = Fact.
Do you want a hot or cold spark? Depends...do your research.
For 99.9% of our Maxima's, Platinums or Iridiums "perform" better and last longer, as well as have a lesser tendency to misfire and can withstand higher temperatures for longer periods of time.
Old Aug 18, 2006 | 03:21 AM
The cheapest set of platinums I've seen are the Bosch, which I wouldn;t use in a Japaneese car. Denso p[lats are 7.49 each and I forget how much NGK plats are. MAybe 5-6 each? Stick with Denso or NGK
Old Aug 18, 2006 | 11:19 AM
aznprid972's Avatar
The guy I know at the store said you won't feel a difference between the two unless you were boosted or spraying.
Old Aug 18, 2006 | 12:05 PM
95mtlMAXSE's Avatar
shift_Puff
i got 6 for $36 buck, NGK platinum....there are 2 platinum models available with the NGK. Both good...
Old Aug 18, 2006 | 12:08 PM
MDeezy's Avatar
This question pops up very frequently and here is the truth:
OEM Plugs that came with the car are Platinums.
Coppers perform just as well as the platinum but have half the lifespan, but also cost half as less.
Gas economy will not change as a result of running new platinums instead of new coppers. Unless you are boosted or using Nitrious the coppers will do as good as a job as the platinums assuming you dont mind changing them sooner and keeping a little extra money in your pocket.
Old Aug 18, 2006 | 04:18 PM
progrocker's Avatar
They weren't? I bought 6 NGK model BKR5EGP plugs at Advance Auto last week, they're 3 bucks and change each, and they're definitely platinum.
This plug has a very thin platinum conductor maybe that's why it's less costly.
Old Aug 18, 2006 | 04:35 PM
JwaxMax99's Avatar
You got the G-Power platinum, BKR5EGP NGK's cheaper alternative at $3.00 OE are the Laser Platinum PFR5G-11 $10.99
Old Aug 19, 2006 | 12:55 AM
Godson's Avatar
Yea they are the cheaper ones,I saw the paper ad and freaked and went down there I was all about to buy like 12 of them and then realized the same thing....
Old Aug 19, 2006 | 12:56 AM
D-Bo's Avatar
Droppin logs
I always go with the Platinums.
Old Aug 19, 2006 | 05:40 AM
Bobo's Avatar
The OEM laser platinums will last longer than 60K. I know someone with a 99 Maxima with 90K on the clock. He is still running the original plugs and the car runs like a champ.
I am stilll running the original OEM laser platinum plugs at 64.5K in my 95 Maxima SE. I will have owned the car for 12 years on October 1 and have no intention of changing the plugs until December 2007 when I have to go through emissions testing.
I would have been on my 3rd set of coppers at least by then, if not 4th as a result of corrosion.
OEM plats all the way for me!
Old Aug 19, 2006 | 07:54 AM
progrocker's Avatar
Considering it's much lower price, why (if at all) is the G Power plat inferior to the Laser plat?
Old Aug 19, 2006 | 08:00 AM
Well, a "laser platinum" plug is supposed to be within a higher tolerance spec because a laser was used to form the electrode. Most cars on the road will not notice a difference.
Old Aug 19, 2006 | 08:33 AM
Iron Scimitar's Avatar
Tha Snatcher
OEM is platium, stick w/ plats.
Excalibur23
Oct 13, 2015 04:33 PM
Turbobink
Aug 15, 2015 07:20 AM
