Symptoms of bad tie rods?
Old Aug 17, 2006 | 09:19 AM
maxfanfromohio's Avatar
Shiver me timbers.
Inner or outer. I am looking for information on both.
Thanks!
Old Aug 17, 2006 | 09:45 AM
95bluse's Avatar
Thanks!
I have a bad inner tie rod on the passenger side which was found when I went for an alignment. Symptoms are a tendency for the car to follow minor road imperfections, meaning there's a tug on the wheel on either side over less than perfect road surfaces. It's quite easy to isolate, just jack up the car & firmly grab the tire at 3 & 9 o'clock positions. Try to move it in & out, if there's movement take a look at the tie rod as you do this. On my car, I can see the play & hear the metallic thunk as the inner tie rod moves. I suspect the outer tie-rod will be similar to spot.
Good luck!
Old Aug 17, 2006 | 10:19 AM
Shiver me timbers.
Good luck!
Thanks for the post. I will try this when I get home.
Old Aug 17, 2006 | 10:44 AM
95bluse's Avatar
Thanks!
BTW what symptoms do you have?
Old Aug 17, 2006 | 11:56 AM
IlyaK's Avatar
The Golden One
Yeah same thing as said above. I have Toyo Proxe's in the front which are known to follow the road imperfections but I had the same issue...I went for an alignment at sears and they told me I had bad tie rods (I hit a deer a few months ago and then ran over it after hitting it - lol) so I think the deer did something to mine.
Old Aug 18, 2006 | 06:22 AM
Shiver me timbers.
It sounds very similar to what you were experiencing. When I hit a bump the car will pull to one side or the other. The steering wheel just kinda turns in my hand.
Old Aug 18, 2006 | 07:06 AM
aznstormin's Avatar
is there a picture to show where the inner/outer tie-rods are? i'd like to check this as well, but then i wouldn't know where to look -.-
Old Aug 18, 2006 | 07:31 AM
95bluse's Avatar
Coincidentally, I'm getting mine replaced right now . I can't do it myself because of the special tool required. Just heard from my mechanic that the steering booth is busted, so that has to be replaced also...oh well as cars age, things wear out.
Here's an excellent write-up with pictures on how to replace it.
http://www.cardomain.com/ride/348507/13
I got it from this thread that addressed sloppy steering. I've just replaced my lca's too.
http://forums.maxima.org/showthread.php?t=391391
Old Aug 18, 2006 | 07:33 AM
GarciaMaxima's Avatar
sound like the same symptoms I'm having. Are tie rods expensive? is it something I can attemp to replace myself? (I've done my own alternator and starter)
Old Aug 18, 2006 | 07:47 AM
95bluse's Avatar
See post above regarding replacement. You need the right tool, it's not that hard otherwise. Cost varies from really cheap eBay ones to Nissan OEM. You can get very good quality MOOG or TRW ones cheaper than dealer (like most parts). My mechanic got mine for $65CAD, I'm not sure who makes it, I'll ask him.
Old Aug 18, 2006 | 07:50 AM
Thanks for the info.
user 11122324
42
Jul 18, 2022 03:35 PM
chisam14
Nov 6, 2018 08:56 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
