will STI Rims fit an 01 max
Old Aug 21, 2006 | 06:25 PM
2001semax's Avatar
http://cgi.ebay.com/ebaymotors/17-20...spagenameZWDVW
Here is the rims from ebay...just curious if the rims will fit an 01 with out any issues...
Any positive feedback is appreciated greatly
thanks guys
Old Aug 21, 2006 | 08:49 PM
limsandy's Avatar
They should fit alright but you might need spacers to push the wheels out a little bit.
Old Aug 22, 2006 | 03:33 AM
Caracicatriz's Avatar
What was that?
^^ +1. Everything seems to be good except for the high offset. Get some spacers and they should fit fine.
Old Aug 22, 2006 | 04:25 AM
2001semax's Avatar
what size spacers do i need? where can i get them? i wouldnt need to get longer bolts would i?
Also would i need hubcentric rings or do you guys think just the spacers would do?
Old Aug 22, 2006 | 07:52 AM
showoff's Avatar
you'll need 10-20mm spacers for sure...Use Eibach and YES you will deffinetly need longer studs. The 20mm Eibach come with built-in studs. I beleive the 10mm ones you have to replace the wheel studs yourself.
Old Aug 22, 2006 | 10:36 AM
phenryiv1's Avatar
Mod her. Ate her.
When did subaru go from 5x100 to 5x114.3? Or is that an STi-only thing?
Old Aug 22, 2006 | 04:07 PM
i30dvr's Avatar
yeah i thought suby was 5.100....?
Old Aug 22, 2006 | 06:13 PM
CCS2k1Max's Avatar
For the 2006 MY STi IIRC. I am still trying to find out the center bore. The 5x100s had a 56 mm center bore. I am not sure if they changed that too.
Old Aug 22, 2006 | 08:14 PM
irish44j's Avatar
retired moderator
as stated above, you would definitely need spacers of at least 15mm. Frankly, though, I am always against using spacers that thick, particularly on the drive (front) wheels.
For that much money, you can certainly get some nice wheels that actually fit correctly, IMO.
Old Aug 23, 2006 | 05:10 AM
2001semax's Avatar
Irish,
Im not to familiar with spacers. Why do you think that using spacers of 15-20mm not good. Is it dangerous? Could something bend or break.. ?
thanks for yor input
Old Aug 23, 2006 | 05:37 PM
irish44j's Avatar
retired moderator
spacers are ok, but you need to be very sure of a few things:
1. that the spacers are hub-centric and have the correct hub bore on the inside to match up to the maxima's hub, and on the outside to match up to the Subie wheels (not sure if they are the same bore or not). That, or get hub-centric rings for the wheels. The weight of the wheels should be held by the hub bore and the lugs combined, not one or the other.
2. since you're going to be using considerably longer lugs, you better make damn good sure that they are high quality
3. I would not buy any brand of spacers other than H&R. Period.
Old Aug 23, 2006 | 07:03 PM
CCS2k1Max's Avatar
If this is right, the STi wheels will not fit w/out mods. The center bore remained unchainged from this auction description.
http://cgi.ebay.com/ebaymotors/2005-...QQcmdZViewItem
Old Aug 23, 2006 | 07:14 PM
2001semax's Avatar
what is the center bore for our cars? this is all new too mee...thanks all for the info
Old Aug 23, 2006 | 07:19 PM
CCS2k1Max's Avatar
66.2 mm
10 char
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
MaxLife17
Sep 8, 2015 02:36 PM
pktaske
Sep 4, 2015 08:40 AM
