will STI Rims fit an 01 max
http://cgi.ebay.com/ebaymotors/17-20...spagenameZWDVW
Here is the rims from ebay...just curious if the rims will fit an 01 with out any issues...
Any positive feedback is appreciated greatly
thanks guys
thanks guys
as stated above, you would definitely need spacers of at least 15mm. Frankly, though, I am always against using spacers that thick, particularly on the drive (front) wheels.
For that much money, you can certainly get some nice wheels that actually fit correctly, IMO.
spacers are ok, but you need to be very sure of a few things:
1. that the spacers are hub-centric and have the correct hub bore on the inside to match up to the maxima's hub, and on the outside to match up to the Subie wheels (not sure if they are the same bore or not). That, or get hub-centric rings for the wheels. The weight of the wheels should be held by the hub bore and the lugs combined, not one or the other.
2. since you're going to be using considerably longer lugs, you better make damn good sure that they are high quality
3. I would not buy any brand of spacers other than H&R. Period.
If this is right, the STi wheels will not fit w/out mods. The center bore remained unchainged from this auction description.
http://cgi.ebay.com/ebaymotors/2005-...QQcmdZViewItem
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
