Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Binding on passenger side front after lowering springs
Old Sep 4, 2006 | 04:48 PM
ryanvalin's Avatar
I just put on my Tein H-Tech lowering springs, and am having a slight issue with a clunking or binding noise when turning at very slow speeds. It does it when I turn both ways, and it sounds like it is in the pivoting top collar where it attaches to the car at the top of the wheel well. What is going on with this? Has this happened to anyone before? Will I need to change the top of the strut mount?
Old Sep 4, 2006 | 05:16 PM
Matt93SE's Avatar
STFU n00b!
Check the plastic bearing at the top of the mount and make sure it's in good shape and isn't binding up on you..
Old Sep 4, 2006 | 07:34 PM
irish44j's Avatar
retired moderator
I've been having this problem since I took off the camber plates....I checked out all of the uppe mount components (bearing, seat, etc) and they all looked fine. Just some light clunking when turning at VERY slow speeds (<5mph) or stopped. I've more or less given up on it - checked everything on the suspension and it looks fine and tight.
Hope you solve the problem so I will too
Old Sep 5, 2006 | 06:08 AM
Kevlo911's Avatar
Kevlo for President
Yeah sounds like the upper strut bearing has dried up
Old Sep 5, 2006 | 02:58 PM
irish44j's Avatar
retired moderator
dried up? Are you talking about the plastic/teflon piece or the rubber-filled bearing?
Old Sep 5, 2006 | 03:08 PM
Kevlo911's Avatar
Kevlo for President
There is only one upper strut bearing? It has grease in it.
Old Sep 5, 2006 | 03:43 PM
ryanvalin's Avatar
The bearing is fine. This problem blows. I can't figure it out.
lux97Max
Sep 14, 2015 03:54 PM
homeyclaus
Sep 3, 2015 06:15 PM
KGMtech
Aug 18, 2015 09:21 AM
twotonezed
Aug 16, 2015 11:41 AM
BassAddictJ
Aug 4, 2015 11:38 AM
