Best way to determine the Tranny type?
Old Sep 15, 2006 | 11:24 AM
spamman's Avatar
I have a 1997 SE 5-spd and the tranny is getting ugly. Basically you can hear the bearings inside getting sloppy and making a whirring noise as you accelerate. i just put in a 5th gen clutch (NOT re-man) and brand new flywheel as my clutch basically imploded. My tranny still makes the noise and my mechanic said the problem is the tranny. NOW, he located some used trannys that hold some warranty and certified testing and in working condition per the seller. His question is whether it is limited slip.
What is the best way to determine whether it is limited slip or not? Is there a code somewhere to tell me that or can I perform a proven test to tell me which type to get for this car?
Thanks: e3
Old Sep 15, 2006 | 11:35 AM
Nealoc187's Avatar
SLOW
on the vin plate on the firewall in the engine bay on the passenger side. if it has a V at the end of the trans code it is limited slip, if it has an A it is open diff.
if your car was brand new in the united states it doesn't have limited slip. no 4th gens in the states were offered with limited slip, only in canada.
Old Sep 15, 2006 | 11:48 AM
scrhale's Avatar
Just get limited slip anyway and buy a new driver's side axel ... done deal.
Old Sep 15, 2006 | 11:50 AM
spamman's Avatar
What is the benefit of getting a limited slip? Also, to change out the drivers side axle - how much for the part and approx. how much work while the tranny is out? Thanks: e3
Old Sep 15, 2006 | 11:53 AM
MaximaSE96's Avatar
Maxima Owner
the part will be bout 100 bux....virtully no work cuase u have to pull the axles out anyway....its a direct swap.....and changing axle seals takes about 2 min with the tranny out of the car already.....u may as well upgrade to a 5th gen clutch too
Old Sep 15, 2006 | 12:06 PM
spamman's Avatar
Well, i just swapped in a 5th gen clutch 1 week ago, then with the car running the tranny problem was apparent. Unfortunately I did not get a chance to diagnose the tranny problem prior to the old clutch blowing up. But I do have a 1 week old 5th gen (non re-manufactured) clutch in. Nice and smooth. i have not gotten on it since I am afraid to stress the tranny at this point. Once it is broken in and the tranny is fixed, I plan to give it a good ride. My mechanic will be doing the tranny swap, so it may be hard to convince him of the lim-slip + different axle combo. He will swear to some voiding of his warranty or some crap.
Old Sep 15, 2006 | 12:18 PM
MaximaSE96's Avatar
Maxima Owner
just tell him what we say...its a direct bolt-on with a different axle that can be bought at autozone.....
Old Sep 15, 2006 | 07:40 PM
spamman's Avatar
Can you guys hook me up with a Nissan or autozone part # if i decide that route? Also any feedback on whether trying to find the limited slip is really worth it? I am looking for a nice proven used one.
Anyone in MA have one?
Old Jan 17, 2007 | 10:15 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
Hey Ed I think I know someone local with a 5 spd limited slip I will check if he still has it. The guy I know with a 5 spd swap says its worth having the limited slip especially if you drive the car in the winter.
Old Jan 18, 2007 | 03:03 AM
dgeesaman's Avatar
Maintenance Monster
The limited slip definitely helps in situations where one wheel likes to spin. This is usually mid-turn on a low-traction surface. For racing and winter driving it's great because you can use more throttle in a turn. With an open diff one wheel just spins when you try that.
Dave
Old Jan 19, 2007 | 01:05 PM
ThurzNite's Avatar
Ask yourself, how often does your front wheel slip? Never? Then you don't need it. Dunno if your wheel slips? Eh, don't bother, let someone else who needs the LSD get it.
Jae
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
