Theoretical speed
Old Sep 17, 2006 | 09:50 AM
KK1's Avatar
KK1
Theoretical speed
Hy to everybody!
Can somebody tell me what is 4th. gen. Maxima 3.0 V6 with autom.transm.
theoretical sped at 6500 revs?
Thanks!
Old Sep 17, 2006 | 10:02 AM
THT's Avatar
THT
Throbbing member
Originally Posted by KK1
Hy to everybody!
Thanks!
1. Find long stretch of road
2. Drive down it and record speed at 6500rpms
3. ???
4. Profit
Old Sep 17, 2006 | 10:21 AM
eng92's Avatar
At 6500 rpm in 4th, using the stock tire size and gear ratios from the 98 fsm, I get about 189 mph.
speed = [(6500 rev/min) / (0.694 * 3.619)] * (60 min/hour) / (823 rev/mile)
What is the point though? You are power limited to approximately 140 mph
Old Sep 17, 2006 | 02:35 PM
MadMaxSE-L's Avatar
Doggah Bite...
and aerodynamically limited to way less than 189...
Old Sep 17, 2006 | 05:28 PM
scrhale's Avatar
Unless you are trying out to get into Fast and the Furious 4, why do you need to know. Anything above 120 is WAY too fast for public roads. I don't care how open or desolate that area is, there is always that possiblity that SOMETHING, SOMEONE, or SOMEHOW an accident may occur. No one can argue against the fact that the chances of you getting into an accident exponentially increases as you increase speed. At 120+ it is extremely difficult to watch the road ahead for any obstructions and properly be capable of avoiding them unless you are Tony Stewart.
Heh, not to mention you are never going to make it passed 120 without the longest road you have ever seen or an 00VI/MEVI.
Old Sep 17, 2006 | 05:48 PM
MadMaxSE-L's Avatar
Doggah Bite...
um, not exactly. My 97 SE 5-spd is mostly stock and I can peg out my speedo on certain bridges in Tampa that are not very long, but 5spd >>> auto
im mean I could if I chose to do so, but that is really dumb and I would never attempt it unless at the track...
Old Sep 17, 2006 | 05:53 PM
sunten1
Well might as well call dibs if you have a Black Stereo Trim (that goes around the HU/Bose)
Old Sep 17, 2006 | 06:04 PM
Black Maxima
In P, I get about 0 mph at 6500 rpms.
Old Sep 17, 2006 | 06:44 PM
Zack342's Avatar
153mph in 5th @ 6500 on a manual.
Auto not sure.
Old Sep 17, 2006 | 06:59 PM
'96 B-rad's Avatar
Um no..in my old stock '96 auto i went 125 mph. Just dont drive with overdrive on.
Old Sep 17, 2006 | 07:03 PM
Black Maxima
I go 203.7 mph in the 1/8 mile.
And that's at 6499 rpm...
Troo Story
Old Sep 17, 2006 | 07:13 PM
MDeezy's Avatar
in what gear? probably around 34mph in 1st gear at ~6500
Old Sep 17, 2006 | 07:21 PM
Tatanko's Avatar
Bacon Lover
Definitely wrong. I've done 125 several times on fairly short stretches of road (by short I mean the space it TOOK, the not the space I had to use), and only stopped at 125 because I have S-rated tires. The car definitely still had pull in it, and that's even with the stock manifold.
Old Sep 17, 2006 | 07:39 PM
96blkonblkse's Avatar
120MPH was easy in my 5spd and was still pulling pretty damn good! 120MPH in my auto and still pulling, if your planning on going 120+ which i dont reccommend on public streets, turn off overdrive, and at redline in 3rd turn it back on.
Old Sep 18, 2006 | 04:59 AM
scrhale's Avatar
I didn't say you can't make it passed 120. It is just very hard. The car pulls extremely slowly and you are increasing speed at a very low rate. Granted this person is a noob and probably doesn't know the O/D off trick anyway. If you have mods then obviously it will pull better. I had intake/y-pipe and once I hit 120 it was like a brick wall on my auto. My 5-Spd is a different world.
Old Sep 18, 2006 | 06:05 AM
NmexMAX's Avatar
dot dot dot ...
193.7 w/ 95/6 SE 215/60-15's.
I have a spreadsheet w/ A32/33/B/34/Z33 4AT-6MT's.
I'll be here all week.
Old Sep 18, 2006 | 06:50 AM
Fr33way™'s Avatar
Wild for Width
Unlimited MPH.
Old Sep 18, 2006 | 11:42 AM
Tatanko's Avatar
Bacon Lover
Very hard? I've done it several times on relatively short stretches of road. Never once have I used the O/D off "trick" either. I wouldn't call 120 a wall, either, as I was still pulling very solidly at that point.
Old Sep 18, 2006 | 01:48 PM
scrhale's Avatar
Are you stock?
I was doing 120 in the steaming heat of GA. The freezing cold weather in PA can attribute to it.
Old Sep 18, 2006 | 02:05 PM
Tatanko's Avatar
Bacon Lover
Are you stock?
Freezing cold weather? Any time I've done these runs it's been the dead of summer, usually 90 degrees outside and relatively high humidity
Old Sep 18, 2006 | 04:33 PM
scrhale's Avatar
But you didn't answer if you were stock or not.
Old Sep 18, 2006 | 04:34 PM
Tatanko's Avatar
Bacon Lover
I had a y-pipe, that was it.
Old Sep 18, 2006 | 04:52 PM
'96 B-rad's Avatar
Nah it was pretty easy to make it to 120 in my old stock '96 auto and I doubt I had o/d off every time I did it. You only really need to do the o/d trick to make it to 135+ But 125 was fast enough since I didnt really want to die.
Old Sep 18, 2006 | 05:16 PM
MadMaxSE-L's Avatar
Doggah Bite...
all my 120+ mph runs were here in FLA, in summer w/ very high humidity w/ stock cars-did it in all 3 Max's I had, 95auto, 97 auto, and much easier in my 97 5spd. again no mods whatsoever, just good tires
Old Sep 18, 2006 | 05:35 PM
nsnrider's Avatar
120 is easy, when i first got a max about 4 years back, i hit 137 mph in a bone stock car with gle rims and tires. I was trying to hit 140 but had to brake fast since i had two cars in front of me blocking both lanes, (two lane road). The funny thing is that the governor didn't kick in at 120 like it should have. Anyways, a year later when me and a few friends drove cross country to oregon, on the same car, the governor worked and we couldn't go passed 120...go figure. But that was when i was single and a bit more risk taker, after numerous of$400+ tickets, I learned to drive the speed limit. Sort-off.
Old Sep 18, 2006 | 05:40 PM
'96 B-rad's Avatar
Wow $400 tickets that sux. You should invest in a valentine v1 for that amount of money..
Old Sep 18, 2006 | 07:00 PM
Fr33way™'s Avatar
Wild for Width
Yes, another e-c0x0r contest!
Old Sep 18, 2006 | 07:26 PM
NmexMAX's Avatar
dot dot dot ...
IAecoxxorfight
Maxima tachs are off
Here's my A33B
Old Sep 18, 2006 | 07:27 PM
Apparition's Avatar
Ichiban King
Originally Posted by NmexMAX
IAecoxxorfight
Here's my A33B
NICE.. friggen c0x0rz
Fr33way™'s Avatar
Wild for Width
IAecoxxorfight
teh old news....
I know, think of the n00b5
Old Sep 18, 2006 | 07:29 PM
Fr33way™'s Avatar
Wild for Width
BTW I wish that pic had sound with those headers.
Old Sep 18, 2006 | 07:31 PM
Apparition's Avatar
Ichiban King
NMexMax A33B = Teh.Sex.
Old Sep 18, 2006 | 07:34 PM
Fr33way™'s Avatar
Wild for Width
Thank you for re-stating my post.
Old Sep 18, 2006 | 07:35 PM
NmexMAX's Avatar
dot dot dot ...
My favorite dyno sound was when I dynoed with the stock everything...except for headers (stock air box, cat back ).. but the headers sounded And everyone thought it was stock
Old Sep 18, 2006 | 07:38 PM
Fr33way™'s Avatar
Wild for Width
:thisthreadisworthlesswithoutvids:
Old Sep 18, 2006 | 07:39 PM
Apparition's Avatar
Ichiban King
post count ^
Old Sep 18, 2006 | 07:42 PM
NmexMAX's Avatar
dot dot dot ...
This thread = worthless
Me = have no vids....Only dynotellos.
Fr33way™'s Avatar
Wild for Width
Copying my location FTL. F'ucking BITER.
Old Sep 18, 2006 | 07:45 PM
Fr33way™'s Avatar
Wild for Width
This thread = worhtless
They are all that matter at the end of the day, but I do just watch videos from time to time for the "oohhhh" factor. </ricer>
Old Sep 18, 2006 | 07:47 PM
Apparition's Avatar
Ichiban King
lmao, Nissan6 made me do it.. yell @ him instead.
