View Poll Results: What cams would you prefer??
REVUP
13.64%
EBAY
25.00%
Other
15.91%
Stay with regular 3.5
20
45.45%
Voters: 44. You may not vote on this poll
Poll: Ebay knockoff or REVUP???
Well looks like a 3.5 is in the works for this winter, just trying to get some opinions for cam selection. I don't want to spend more than the cost of these cams. Both have their own advantage but under FI conditions what would you perfer?
Specs:
RevUp VQ35:
248-degrees duration 10.5mm lift(Per SR20DEN)
Ebay Knockoff:
260 Degrees Duration / .428" (10.9MM) Lift (Intake Cam.Advanced 2 Degrees)
I know the Revup has negative overlap which is great for FI since the intake and exhaust valves would never be open at the same time for boost to blow thru but it also has lower duration. I don't know enough about durations to know the benefits and the disadvantage.
So discuss...
Specs:
RevUp VQ35:
Ebay Knockoff:
So discuss...
Whats different about the exhaust cams? is it thicker than the intake sprocker or is it because of vtc (06 350z came with VTC on exhaust side too right?)?
I remember reading about some machining may or may not be required.
Originally Posted by mforrest100
None of the above....Scott Performance Cams....made for boost in which they have minimal overlap. Check my350z.com.
Mike
Mike
i would be careful of cheap camshafts, this is not some simple thing like a w.g or bov.. think of what could happen if those cams are off spec. , alot can go wrong in the head
you plan on shimming the valves as well? replacing new keepers?
JWT springs and shims are planned but I dont plan on reving more than 7 to 7.2k
Originally Posted by jcy98maxse
have had some research on the ebay cams, they show decent gains and from what I have heard the quality is better than stock. I know Jime and a few other Altimas that are running these and have not had a problem.
JWT springs and shims are planned but I dont plan on reving more than 8 to 8.2k
edited for what you really mean.....
that could be nice if theres a IM that would make power up there... plus the springs are really for protection from valve float when I am boosting 15-16psi at that rpm.
Mike
Mike
Another question is, since these cams are made for the 350z and does not require any drilling or adapters like we do for our swap. How would that affect the cam if any by putting them with the 3.0 timing equipment? Will the cam seat the same way in relative to what a regular 3.5 would?
Additionally, I would like to add another candidate to your selection which will probably be available by the time you will be doing the swap: JWT C2 cams. Suppose to be some great cams. Search these on my350z as well.
Mike
Actually, they will require the adapters. All VQ35 cams are the same. Doesn't matter which car until you get into the 04 and up range which has the rev up cams. The Scott cams would be installed just like the stock cams for a VQ35. I hope others will chime in to let me know if I am incorrect in my assumption.
Mike
Mike
Who makes cam adapters? Both Tilley and Stephen Max or just Tilley?
I thinking if either of them were interested, I can buy the REVUP cams and send it to either of them and see if they can make adapters for the exhaust cam. Especially Tilley since he has access to 3.5s in his shop, I'm thinking if it works it would benefit the org and allow us to have a better cam option for FI.
I would send the cams to stephenmax if possilbe, you might want to have a look at the thread about tilley in the all motor forum.
IMO, you're already building the motor, you might as well go with aftermarket cams while you're in there.
PMed Along from my350z, he seems like the person that made this work on the 350z:
To ALong:
I was told from a guy on the max.org that you put some revup cams in a non revup head. I just had a few questions for you since if this would work, it'll be great for my turbo setup. So I have a few questions:
-what was involved to make this fit? any machining? i heard u need to replace the bolts with longer ones, are you talking about the camshaft bracket bolts?
-is it a must to get some stiffer valve springs or rev up retainers? Can stock 3.5 or 3.0 sorings handle it on a 6500rpm redline?
Thanks for your help. I'm really interested in making this work for me since I'm currently doing a motor swap also so the cam install would not be as difficult as compared to the motor being in the car. Thanx again
JY
Replied from ALong:
2006 cams are direct bolt in. Exhaust cams will need longer bolts, will need to source them from a fastener supplier. Try to install the 04 bolts and you will see what you need as far as length.
You dont need to change valve springs but it is a good idea
To ALong:
JY
Replied from ALong:
Becareful w/ the c2's as they are the aggressive and you may have overlap issues.
I vote for sticking w/ what is tried and true and use the ebay knockoffs. They are proven performance wise and quality wise. Again the c2's are unchartered territory. I know when i tried the nismo cams when i did my 3.5 swap i was running into overlap issues at idle which i think may have been caused by them being to aggressive.
BTW have you considered using a staggered setup? I have read a few articles that claim running a larger intake cam in conjunction w/ a smaller exhaust cam can actually help increase power while also helping with spooling the turbo. In that case you might want to consider the tomei cams since you can choose seperate intake and exhaust cams
litch
123
Jan 4, 2024 07:01 PM
magiconthetire
Oct 26, 2015 09:03 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
soybeanz
Sep 25, 2015 10:46 AM
