speed sensor wire
speed sensor wire
I need help locating the speed sensor wire, wether next to the ecu or behind the tach, which ever.
I am hooking up a pioneer double din navi and i need to tap into the speed sensor wire.
Maybe someone else will look it up or knows where it runs. Comes from the tranny. Not sure why a speed sensor would need to go to a deck anyways... Here is a pic behind the dash. pin # 17 or 62 goes to the gauge, assumably from the speed sensor... Tap into those 2 wires with an ohmmeter and see which one changes resistance in relation to speed change.
Originally Posted by maxspeed96CT
cool thanks man, the navi has to hook up to the speed sensor to get a more accurate idea of exactly how fast the car is traveling and the direction and etc...
Originally Posted by GBAUER
but... it's navi. Shouldn't it already know that? Seems a little dumb to me. In fact, when I got new rims and tires I used the navi on my phone to make sure the OD was still the same as the OEM set-up by compairing my speedo to the navi speed.
so does anyone know which wire it is for sure?
if worst comes to worst i wont hook it it, like i said it DOESNT NEED IT , it just says it makes it hlep the navi be more accurate and etc...
exactly, that means your navi IS hooked uop to your speed sensor........
hooked up the navi but didnt hok up the speedsensor wire, everything seems to work ok,
im still gona do the speed sensor wire , the install took me longer than it should of and it got dark and etc...
Guess the wire realy isnt nessecary
http://forums.maxima.org/showthread....82#post5288882
The Frye
Sep 2, 2021 11:03 AM
Max139617
Sep 6, 2015 06:02 PM
sdotcarter
Sep 2, 2015 09:53 PM
