Window Modules with 791
A 791xv on its own has nothing to do with window modules at all. 530T is DEi's window module, and yes, you can still use the factory window switches as well as the remote.
It does have 6 channels...two of which are lock and unlock. A third channel will be used for trunk pop. Assuming you are adding 530T's, a fourth channel, as well as ground when armed, will be used for windows. So you have two channels left to play with, which can be used for anything you want.
Also can you point me in the direction of the BCM and the NSS?
Wait. Do you have factory window roll up/down from the factory remote? If so, yes you can integrate that with the 791 without anything extra. If not then youll need 530T's. I always forget which 4th gens had em, and assumed yours didnt since 5.0 gens like mine didnt.
Originally Posted by Pearl96Max
The 4th gens had it, but would only do down. The wires are at the BCM.
Will Not give..
One touch all around
Roll up upon arming
Both of which the 530T does.
Will Not give..
Roll up upon arming
knight_yyz
Nov 1, 2015 01:34 PM
