SunRoof Rattles?
Old Oct 14, 2006 | 03:13 PM
Skylowmax's Avatar
SunRoof Rattles?
Hey Guys, i dont know if this question has been posted before so dont flame please, but my sunroof is going nuts. When i'm driving and i got my sunroof on (TILT mode) it rattles like crazy when i go over bumps and so. I just want to know IF any of you guys have encounter this problem. Oh the rattles only happens when sunroof is on TILD MODE....any suggestions?
Old Oct 14, 2006 | 03:45 PM
misiek's Avatar
mine rattles all the time.... i believe housecor had a fix for this.... you gotta get some shims from nissan... i still didnt get a chance to do it but im going to the dealer for service soon so ill ask for them then
Old Oct 14, 2006 | 05:44 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
You can get shims from any parts store. Find the one with the variety set though so you can adjust how you need to as oppose to using five small shims or six... whatever.
Here is housecores link, this will show you how to remove...insert...adjust...etc.
http://www.innerbean.com/housecor/
Old Oct 14, 2006 | 05:49 PM
Maxfli's Avatar
Misiek - the shims are for adjusting the sunroof to eliminate wind noise.
The rattle is probably just a nut that needs to be tightened. There are 4 nuts that hold the sunroof glass to the metal brackets that the sunroof slides on -- one or more of these nuts are probably loose. Follow Housecor's or the directions on this site (http://www.cardomain.com/ride/695690/6) to remove the trim pieces and then you will have access to the nuts. If you have alot of wind noise from your closed sunroof while driving (I did), you loosen these nuts to adjust the height (by adding shims or regular flat washers -- Nissan charges almost $5 per shim) and move the glass front/back and to the right/left in the sunroof opening to eliminate the wind noise.
This is a 10 minute fix.
Old Oct 14, 2006 | 06:16 PM
Skylowmax's Avatar
wind noise is not my case here.....Maxfli thanks for your adviced, i will check mines tomorrow and see if any of the 4 nuts need to be tightened...I will post tomorrow to let you guys know the results...Thanks to all for the replies...
Old Oct 15, 2006 | 08:15 AM
Skylowmax's Avatar
Tightedbed ALL 4 nuts, rattle is some what minor NOW. Anyway is kool it doesnt bother me that much since i always be rolling with my radio crank UP..thanks for the adviced...
user 11122324
42
Jul 18, 2022 03:35 PM
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
