Problems with brake bias (BBK)?
Ive heard of a few guys saying that the addition of a BBK up front is eating up their rear calipers/rotors due to brake bias. Is this a major issue for most people and if so is there a way to alleviate it? thanks guys,
Grant
Grant
Not with my original 12.2" Fastbrakes or my modified 13" Fastbrakes;
Nor do I have that problem with my AP Racing Kit either...
All those kits have a greater piston surface area than stock (3.14 in/sq) at least on 4th Gen. That coupled to a greater torque arm radius of the larger rotors...
Ok cool, I just got some Z32 aluminum 4 piston 30mm calipers and 13" RTP slotted rotors so hopefully they'll work well. Ive heard good things about the setup but just trying to get several opinions, thanks!
Grant
Grant
I haven't had that problem.
I think that is only happening to some of the 6th gen guys who have the electronic brake proportioning system or whatever it's called....the sensor "reads" the brake bias wrong with a BBK for some reason, apparently.
The sensors think that there is added weight in the rear (as in passengers or cargo) and therefore it applies more braking for the rear.
Dan
Grant
Grant
i'm new to the abbreviation 'RTP'. what does that mean?
Originally Posted by !PrjctMax!
No, it's because the car is lowered. Kam said that when he had Progress springs all around the rear brakes would lite up a lot, but when he put the OEM springs in the rear and did the same test, both front/rear lit up evenly.
Dan
Dan
Kam
Grant
Grant
Where did you get that setup from??
Mar 12, 2020 12:06 AM
bbsitum
Sep 11, 2015 04:55 PM
