Yes LED bulbs for our Gauges.
Old Nov 4, 2006 | 10:22 AM
MyownNismo's Avatar
Future Camaro SS owner
That's right LED bulbs for our gauges. It's number 24 bulb. I got a some in blue and white. I will take pics as I get them in. I am going to try the blues first.
http://autolumination.com/74.htm
Old Nov 4, 2006 | 10:32 AM
meccanoble's Avatar
Sports Button FTW
cant wait to see, u should have posted this when u had pics ready but its all gravy.
Old Nov 4, 2006 | 10:36 AM
Dan5.5's Avatar
hey,
i have a question, are these bulbs a direct replacement, or do u have to make them work? Will these work for a 5.5 gen? Because right after i bought my car, thats one thing thats been bothering me a lot.
Old Nov 4, 2006 | 11:07 AM
MyownNismo's Avatar
They should be the same for both 5 and 5.5. They are in but have to wait till dark but they do work. This is how you have to work with them you have to have your dimmer connected. next if they don't light up you have to turn the bulb around in the twist lock. So far what I can see they light up great with the blue ones. Once I show pics I am sure everybody will be getting them you need 4 of them. I bought 4 white and 4 blues. I can't wait till dark. EDIT: the ones a bought are the super star ones 4 bulbs down on the page.
Old Nov 4, 2006 | 11:26 AM
kobalt's Avatar
can't wait to see the outcome
Old Nov 4, 2006 | 11:29 AM
Adri's Avatar
I can't wait to see it.. This is my next project.
Old Nov 4, 2006 | 12:48 PM
† ErV †
awaiting pics in 3 hours
Old Nov 4, 2006 | 01:01 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I'll believe it when I see it.
Old Nov 4, 2006 | 03:43 PM
MyownNismo's Avatar
My camera doesn't due justice as everybody says when taking pics of lights. Here's the blue I will try the white ones tomorrow.
Old Nov 4, 2006 | 03:49 PM
OutMaxxed's Avatar
looks good ... are there really those light and dark spots or is it just the camera?
waiting for the white ones =)
im assuming u got the 4.99 ones.. if so how many did u buy of each?
Old Nov 4, 2006 | 03:51 PM
MyownNismo's Avatar
It's going to have light and dark spots unlike metal's lights but it doesn't bother me. it's better then the stock lights but not as bright and perfect like metals.
Old Nov 4, 2006 | 04:38 PM
MyownNismo's Avatar
White ones. Not much different.
Old Nov 4, 2006 | 06:41 PM
dafertilizer's Avatar
The white ones actually look darker? is that just the picture?
Old Nov 5, 2006 | 07:52 AM
MyownNismo's Avatar
It's the picture. The white ones highlight the needles better then the blues. They are brighter then stock bulbs which is a plus not super bright like metal maximas. If you don't feel like taking apart your cluster like metal did this is a way to go. They also have bulbs on there too. I am thinking of getting some different faces cause one of my gauge rings slid down and scratched the face of the gauge. I got new rings and waiting for a couple other parts.
Old Nov 5, 2006 | 08:10 AM
mistaks's Avatar
Those look really hot! Instalation is also a breeze?
Old Nov 5, 2006 | 08:42 AM
VaporHead
Looks ok. It would be better if there weren't faded areas. They look like a cluster off a early 90's vehicle with busted bulbs.
Old Nov 5, 2006 | 08:59 AM
ZIPPIN's Avatar
Mauja He Mauja
Side by side comparison with OEM bulbs would show the results better.
Old Nov 5, 2006 | 10:02 AM
soundmike's Avatar
Very sound, Mike
That's just the camera showing how it really is. If you'll look closely on your OEM bulb equipped cluster - the light also has hot spots.
Old Nov 5, 2006 | 02:03 PM
kinesisfilms's Avatar
i bet you could pick up a number 24 bulb from radioshack....i might check it out.
Old Nov 5, 2006 | 07:12 PM
OutMaxxed's Avatar
so all u did was replace the bulbs? u didnt alter the blue plastic thing ive seen in soo many write-ups?
Old Nov 5, 2006 | 07:31 PM
PoLo's Avatar
2-Wheelin it...
aren't these the same size as the center console bulbs (temperature) so you would also benefit by upgrading those bulbs.
Old Nov 5, 2006 | 07:47 PM
bugbite77's Avatar
if you dim your dimmer, do the LED's dim?
Old Nov 5, 2006 | 07:51 PM
PoLo's Avatar
2-Wheelin it...
why would someone want to dim it after upgrading them to make it brighter?
Old Nov 5, 2006 | 07:54 PM
bugbite77's Avatar
uhhh, why not...
Old Nov 5, 2006 | 09:51 PM
kobalt's Avatar
Your cluster looks modified, but would you say that overall it is brighter with these bulbs as opposed to oem?
Old Nov 6, 2006 | 08:29 AM
Teufelhunden's Avatar
anyone try the red? thinkin about white or red, itll be great if you can adjust the dim.
Old Nov 6, 2006 | 08:31 AM
PoLo's Avatar
2-Wheelin it...
uhhh, why not...
because you made them brighter!!! now you want them lower?
it was more of a joke jimmy babe.
Old Nov 6, 2006 | 08:50 AM
MacGarnicle's Avatar
brighter is good, but there are situations where you may want them dimmer.. Was it an easy install? Worth the effort and money for the results?
Old Nov 6, 2006 | 02:12 PM
MyownNismo's Avatar
Yes they dim with the dimmer. My gauges are not modified other then the bulbs. I had chrome gauge rings which I am waiting to put back in. They are brighter then the OEM bulbs. Sure they got brighter spots but the still look better then stock.
Old Nov 6, 2006 | 03:58 PM
Dan5.5's Avatar
Which once would you choose,( whick look better in real life)
thanks
Old Nov 6, 2006 | 04:02 PM
MyownNismo's Avatar
I like the white ones better.
Old Nov 6, 2006 | 07:05 PM
krazysashka's Avatar
was it plug and play? and how many do you need?
Old Nov 6, 2006 | 07:53 PM
san shou fan's Avatar
so it was as easy as taking out the old bulbs and putting these new ones in? "plug and play" as asked in the above post? cause I never tried leds just cause i didnt want to go through all the work and pain of soldering, etc. plus I suck at that kind of stuff
Old Nov 6, 2006 | 08:08 PM
MyownNismo's Avatar
yep plug and play. As stated earlier if they don't light up turn the bulb around in the socket.
Old Nov 6, 2006 | 08:13 PM
sweet thanks for the quick reply... im definitely gonna be ordering these bulbs... another question do you think the bulbs right above the 24's the tri-power 4leds 24's will fit or they too big dimenions wise (15mm x 8mm vs. the 17 mm x 6.5 mm 24's you bought)?
Old Nov 7, 2006 | 11:21 PM
OutMaxxed's Avatar
oh, id like to know, how many bulbs did u order? ive never opened up my gauge cluster b4..
Old Nov 8, 2006 | 03:07 AM
MyownNismo's Avatar
you need 4 they have to be the 24 bulbs the top 3mled ones are the 74's.
Old Nov 8, 2006 | 05:02 AM
Rydicule's Avatar
Don't you know who I am?
How difficult is it to change out the gauge cluster bulbs? What's involved... and... uuh, how do you do it?
I've never messed with a gauge cluster before... but this seems pretty cool
Old Nov 8, 2006 | 07:39 AM
GigEmAgs07's Avatar
indeed, a how to would be super.
Old Nov 8, 2006 | 08:56 AM
PoLo's Avatar
2-Wheelin it...
i'll let someone else explain how to take apart the gauge cluster, but i will state this. do NOT turn on the car while any of the harness are unplugged, you will get a CEL and/or Airbag light. you can reset it, but it's just a PITA. in my case, when i did this a few years back, i just drove like that and after 25-30 restarts, the light disappeared on its own.
