will 16x7.5 5x114.3 offset +42 fit 4th gen ?
Old Nov 9, 2006 | 07:15 PM
Ceasars Chariot's Avatar
Old Maxima Legend
dont know much about rims.
size: 16 x 7.5
5 x 114.3
offset +42
will this fit the 4th gen ?
Old Nov 9, 2006 | 08:39 PM
Chunger's Avatar
My other car is a Hybrid
Stock 97-99 SE rims are 45mm offset so it should be fine...
Old Nov 9, 2006 | 09:56 PM
MrDicks95SE's Avatar
Offset Is Everything.
it should fit no problem.
what 16s are you going with? im thinking about going that route just for ride comfort.
Old Nov 10, 2006 | 01:03 AM
Old Maxima Legend
thanks, would that mean these would stick out further from the fender or be pushed closer up under the fender if that makes sense ? not sure looking at some lightweight wheels and was trying to see if they would be the correct fit
Old Nov 10, 2006 | 10:20 AM
http://marksink.com/tire_wheel_offset/offset.html
use the wheeloffset link. works well.
Old Nov 10, 2006 | 02:27 PM
Old Maxima Legend
is this information true or false ?
Wheels that fit on a Maxima have to have a bolt pattern of 5 x 114.3 or 5 x 4.5 (in inches) with between a 35-40mm offset. For offsets greater than 40, spacers and longer lugs can be used to prevent the rim from rubbing on the suspension arms or inner wheel well with wide wheels.
- http://maxmods.dyndns.org/
Old Nov 10, 2006 | 05:10 PM
Chunger's Avatar
It will depend how WIDE the rim is with 40-45mm offset.... That number is just the distance to the "centerline" of the rim from the mounting surface... Even if you move it way out (30mm) it COULD still rub on the inside if get a 11" wide rim... I hope that made sense...
But for your size I doubt if it will rub on the inside... you could always turn "out" the turn "stops" on the lower control arms to prevent that anyways at the cost of turning radius.
Old Nov 10, 2006 | 06:50 PM
whazzzzuup's Avatar
With those specs, you will probably be able to run 10-15mm spacers easily. A 7.5 inch wide wheel fits well with a ~+30 offset in the front and +20 to +25 in the rear.
Old Nov 10, 2006 | 08:26 PM
Old Maxima Legend
15 x 7
5 x 114.3
42 mm offset
Old Nov 14, 2006 | 06:33 AM
abci30's Avatar
oh noes!!!!1111
i'm currently running 16x8 with a 42 offest and they fit fine with no rubbbing. The front is CLOSE to rubbing the struts. I can probably get 2 fingers in there snug. The front wheels sit flush with the fender, but the rear are still tucked in a bit so i'm getting either a 5 or 15mm spacer would flush it out.
Old Nov 15, 2006 | 09:16 PM
z32drifter's Avatar
Z32 wheels are 16x7.5 +45, you won't have any problems with a +42
look at the pic link with my sig for pics with Z32 wheels
MAXSE5SPD
Sep 17, 2022 04:00 AM
Wareagle92
Sep 3, 2015 07:18 PM
Lowered_a33
Sep 1, 2015 07:49 PM
