What to put on CV Boots????????
I just had new axles put in last Feb.
So today when I was putting in my new rotors and Hawk pads, I noticed the CV boots are alrady starting to crack.....
What can I put on them to stop it from getting worse?????
While silicone spray may help for a little bit, knowing how those boots gets exposed to the elements, that coating will be gone in no time.
What you may want to find out is why did they crack?
Do you drive hard?
just a thought
Do you drive hard?
just a thought
Originally Posted by VaporHead
Spray some silicone or WD40 on them so they don't dry out that bad.
Do you drive hard?
just a thought
Do you drive hard?
just a thought
But yes I do get on it most of the time I drive it
I like the idea about the WD-40, but do you think it may have any degradative effects on the rubber?
Originally Posted by dafertilizer
I was thinking more along the lines of crappy mfg of the boots.
How about some axle grease OUTSIDE of the boot? I think that stuff is definitely thicker than WD40 and it would last longer in those conditions.... since I have it all over my control arm right now.
Originally Posted by FanaticMadMax
So......you get a new boot, rubber don't last forever in extreme weather and temp change constantly.
Definitely do NOT use axle grease. It will collect dirt, debris, etc, which can accelerate the deterioration of the CV boots.
WD-40 will work just fine and won't degrade the cv boots. We used it on Dirt Bikes top to bottom (had to buy it by the gallon...). We sprayed _everything_ once, then we learned to spray everything except the grips and the seat.
Violator
Sep 9, 2015 10:14 AM
