Why are there two muffler tips?
Old Nov 14, 2006 | 04:22 AM
Albert's Avatar
Why does the 6th gen mufflers have two exhaust tips while most other
cars have one? Are the two tips from the same opening or the design
is similar to the 5th gen where one would only open up at a higher load?
Old Nov 14, 2006 | 05:27 AM
04BlackMaxx's Avatar
I think it looks better, its done for looks, nothing more, nothing less.
Old Nov 14, 2006 | 07:24 AM
mixshows
i think it looks sick!
Old Nov 14, 2006 | 07:41 AM
Mikesima's Avatar
Cause it's purdy.
Old Nov 14, 2006 | 09:36 AM
RHMax's Avatar
Newbie just Registered
They are "HIGH CAPACITY" mufflers. I think they do have valves inside like 5th gens. I replaced all stock piping, resonator, and added y-pipe; and I notice that above 3k RPM is quiter than at lower RPM. And quad tip is badazz...
Old Nov 14, 2006 | 11:24 AM
NiZMo1o1's Avatar
Could you give me more details on the piping size ? and also maybe a Sound Clip ? Does it give that Altima SE-R groar ?
Old Nov 14, 2006 | 11:40 AM
SilverMax_04's Avatar
Basically this is correct. It is one of the few indications on the outside of a 6th Gen that you should be careful before you mess with this 4-door car. These 2 pipes indicate that the breathing of the engine should be better than in a 4-door Accord that only has a single pipe.
These two pipes also have the advantage of very slightly reducing the back pressure on the whole exhaust system.
Old Nov 14, 2006 | 11:53 AM
RHMax's Avatar
Never heard SE-R groan, so I couldn't tell you. I went with stock size pipe since I didn't want bigger pipes from Y-pipe to mufflers. If I'd plan to change the mufflers, I would have gone a little bigger. I don't have sound clip, besides, above 3k, all you'll hear is the engine/intake sound. If someone want to host the clip, I'll record it.
Old Nov 14, 2006 | 12:46 PM
kamski's Avatar
.org extraordinaire
Dont want to burst your bubble about Quad Tip exhaust but in reallity, unless you have a dual pipe from the collectors system... it basically sucks and is only for esthetics.
http://www.nissanperformancemag.com/...revenge_nerds/
So if you have on big pipe out of both collectors and then run to one outlets. You can get some serious performance.
Check out a true dual exhaust setup and its gains.
http://www.nissanclub.com/forums/eng...test-pipe.html
Live outside and .org and learn also youg one.
Kamski
Old Nov 14, 2006 | 03:47 PM
!PrjctMax!'s Avatar
Kamski
ale kurwa crazy! I doubt there's enough room for that being done on the Max and the money would be an issue too
Old Nov 14, 2006 | 04:14 PM
kamski's Avatar
.org extraordinaire
Y, the guy at nissanclub did that to his ALTIMA. A_L_T_I_M_A is smaller then M!A!X!I!M!A! more then enough room, but its $900 to get peak performance, hmm or Cattman for $750.....
Damn exhaust parts are expensive.
Kamski
Old Nov 14, 2006 | 04:36 PM
akaxmrxhammer's Avatar
wow, that's a nice setup. i rather pay $150 more and go with true dual exhaust setup.
Old Nov 14, 2006 | 06:23 PM
MisterSparkle's Avatar
lolxz achually for those who've seen our exhaust system...lets just say there's plenty of room down there...just look at the monster of a resonator we havef...lolxz that should speak for itself...lolxz
Old Nov 14, 2006 | 09:06 PM
RHMax's Avatar
Those with 6MT won't have any problems with the true dual setup, 5AT will.
Old Nov 15, 2006 | 06:01 AM
!PrjctMax!'s Avatar
See, I told you Kam.........
Old Nov 15, 2006 | 07:32 AM
xoomer.com's Avatar
I Donate! Why Don't You?
You damn right about it!
Old Nov 15, 2006 | 08:23 AM
kamski's Avatar
.org extraordinaire
Really, do we have any side by side pics to compare the underbody?
Kamski
Old Nov 15, 2006 | 09:48 AM
Stardust's Avatar
F---ing Kangaroos
Old Nov 15, 2006 | 10:32 AM
Glude's Avatar
Originally Posted by Stardust
Old Nov 15, 2006 | 10:37 AM
RHMax's Avatar
Kamski
I didn't mean it's not physically possible. I meant the tranny won't shift properly in the auto mode because of the lack of any back pressure. It will upshift too early. You can get the same effect by going with 3" piping.
Old Nov 15, 2006 | 12:16 PM
Killah Kane's Avatar
looks real good.... I do however, want to put some better tips on them. Any ideas?
Old Nov 16, 2006 | 01:34 PM
REVOLUTIONZ's Avatar
CAN THIS BE USED FOR A MAXIMA? 05?
Kamski
Old Nov 17, 2006 | 09:40 AM
kamski's Avatar
.org extraordinaire
Of course You will need to make the C-pipe longer but it would end up almost the same product in the end.
Kam
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dcam0326
Sep 18, 2015 04:52 PM
TheMafia
Sep 4, 2015 08:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
