My Dyno "sad"
Old Nov 15, 2006 | 03:29 PM
wunfstmax's Avatar
My Dyno "sad"
Well I went to the dyno today, and this was the result.
The dyno is a load bearing dyno, but its not a mustang dyno. That was the corrected numbers from the dyno dynamics dyno to a dyna pack dyno. My air/fuel ratio was horrid, most mid to low 10's. The dyno operator said I could pick up around 20whp just by getting it around 11.7-11.9 range. So far Ive got them to around 11.3-5 with no big changes. oh this is 7psi
The car is a 1997
turbonetics to4e 60-1 hifi
tial 38mm wastegate
greddy e-manage blue
deastch werks 440cc Injectors
3" down pipe
3" exhaust
foward feedpipe
Old Nov 15, 2006 | 03:49 PM
matty's Avatar
What manifold are you using ?? Stock I presume ??
May I ask why the dyno was shut down at 6200 Rpms ??
Get that Emanage onto a computer and get it tuned to where it should be.
-matt
Old Nov 15, 2006 | 03:57 PM
wunfstmax's Avatar
yes its a stock manifold, i dont know why it was shut down at 6200, though it wouldnt have made much of a difference.
Old Nov 15, 2006 | 05:30 PM
speed racer's Avatar
It might have been the operator that shut it down. It happened to me as well.
Old Nov 15, 2006 | 05:51 PM
Blu's Avatar
Blu
the tits
find out which correction factor they used on the Dyno Dynamics plot. If its the DD STD converted number they read about 12-15% low vs a dynojet SAE correction. This has been proven by the 350z guys so its not just a myth.
Old Nov 15, 2006 | 06:17 PM
gtr_rider's Avatar
192.168.1.1
I thought you needed somewhere in the 12.5 range for a FI app.?
Old Nov 15, 2006 | 06:56 PM
matty's Avatar
11 to 11.5 is the sweet spot. 12.5 is kinda pushin it
-matt
Old Nov 15, 2006 | 07:07 PM
Blu's Avatar
Blu
the tits
12.5 is somewhat safe for the SC'ed guys but is pushing the limits for a turbo application. I would tune 12.0 early and richen it up to 11.8 for the last 1500rpms or so.
Old Nov 15, 2006 | 07:11 PM
Kevlo911's Avatar
Kevlo for President
Originally Posted by Blu←
12.5 is somewhat safe for the SC'ed guys but is pushing the limits for a turbo application. I would tune 12.0 early and lean it out to 11.8 for the last 1500rpms or so.
Make it more rich
Old Nov 15, 2006 | 07:25 PM
Blu's Avatar
Blu
the tits
Originally Posted by Kevlo911
Make it more rich
yea
Old Nov 15, 2006 | 07:46 PM
wunfstmax's Avatar
Well If I can get it to hold in the 11.7-11.9 range and pick up 20whp and run 100+ octane I could probably be able to hit 300. Something wasnt right though running it on the street in 3rd gear I see full boost(8.5ish) by 4800rpm. On the dyno though it was only hitting 7 and didnt see full boost until 5700rpm.
I took the guy for a ride after I got off the dyno, and it was what i said. I dont know what was up.
Old Nov 27, 2006 | 07:22 AM
KocheeK's Avatar
advice
u will earn more 20hp when u have 550 Fuel injection
Old Nov 27, 2006 | 07:24 AM
Blu's Avatar
Blu
the tits
tame down that sig, christ!
Old Nov 27, 2006 | 11:27 PM
jcy98maxse's Avatar
Turbo is too much fun!
Please explain what 550 Fuel injection mean? I'm assuming 550cc injectors right? I dont think that is the problem since hes running as rich as he is now, the bigger injectors only make it worse unless he tunes it first. The priority thing is getting a proper tune and if he maxs out the 440cc's then he should upgrade, changing to bigger injector would not gain 20hp like you say.
Old Dec 1, 2006 | 01:11 AM
Duckman540i's Avatar
VE Powah!!!
Mind you, that these numbers are at 5000 plus feet elevation!
Ben2003GLE
31
Jul 17, 2016 08:13 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Chebosto
Dec 19, 2001 06:34 AM
Nismo87SE
Oct 23, 2000 08:15 AM
