Tokico Blues too soft?
Old Nov 17, 2006 | 07:11 PM
Shogunsc4's Avatar
My tech told me that the Tokico HP's I have on the car are way to soft and they are causing the tires in the rear to wear unevenly. He told me that the fronts are fine. Anyone have this happened to them? I have my Blues for about 3 yrs now with the H-techs.
Old Nov 17, 2006 | 07:21 PM
compx's Avatar
I am currently looking to replace my 00 stock struts/springs. Any feedback would be great on this topic.
Have you been happy with the ride? I have family, just looking for something to tighten up the round-a-bouts.
Old Nov 17, 2006 | 07:33 PM
Shogunsc4's Avatar
ride is fairly soft and a little bouncy over bumps but a tad stiffer than stock
Old Nov 17, 2006 | 09:14 PM
steven88's Avatar
Need A Light?
i heard they were soft...near OEM specs...so its advised that you pair up stock springs or maxspeeds with tokico blues
but i thought our rear suspensions doesn't have adjustments? which means if your shocks or other components wore out, it wouldn't necessarily change the camber/toe angles? correct me if i am wrong
try popping your hood...and bouncing your car...it shouldn't bounce more than once....same with the rear...pop open the trunk
Old Nov 17, 2006 | 09:34 PM
DrKlop's Avatar
Driving is the next best thing
It doesn't seem to make any sense... No matter how stiff or soft the shocks are, they do not affect tire wear. (at least during normal driving)
Old Nov 18, 2006 | 05:54 AM
9DTALON's Avatar
Sounds like a pitch to sell you some different shocks, or not to warranty some tires. If the shocks on the rear of your car a working (dampening bumps) then your tires are not going to suffer classic "blown shock" wear. Good luck.
Old Nov 18, 2006 | 12:40 PM
boondoxmax's Avatar
I have blues and they are not to soft. They are stiffer then stock. I have blues pair with stock springs so I know there not to soft. They are firmer then stock and plus I thought tire wear was due to alignment issues.
Old Nov 18, 2006 | 12:45 PM
illlojik's Avatar
I C U
I smell a serious pot of Dude's just trying to get you you to buy some extra cash from you.
Old Nov 18, 2006 | 02:58 PM
djfrestyl's Avatar
Suspension Yoda
Is your alignment off in the front and those wheels recently rotated to the rear? That is the only way I can imagine uneven wear in the rear.
Old Nov 18, 2006 | 03:45 PM
pbn85's Avatar
its NOT the shocks that are contributing to your abnormal tire wear. But yes, tokico blues are soft. I have them and I know it
Old Nov 18, 2006 | 05:43 PM
irish44j's Avatar
retired moderator
that is not true. If the springs and struts are not properly rate-matched, it can cause cupping of tires and other maladies.
Old Nov 18, 2006 | 06:19 PM
Shogunsc4's Avatar
Yeah, that is what he said. There were uneven spots on each of the rear tires. He said something like the rear Blues were too soft to hold the ground. Those damn Michelin Pilots up front went bald in the center of the tires.
Old Nov 19, 2006 | 06:49 AM
djfrestyl's Avatar
Suspension Yoda
Went bald in the middle of the tire? Were they overinflated?
Old Nov 19, 2006 | 09:40 AM
DrKlop's Avatar
Could you explain it in more details? I don't seem to get it.
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
BobTX10
Oct 7, 2015 08:43 AM
