Maxima Timing belt noise??
My 04 Maxima is making a faint screachy noise when i turned it on from a cold start. I let it warm up but the sound has gotten worse. I think its coming from the timing belt but i'm not sure. Is there some lube or something we need to put on the timing belt. Do we need to lube the belt under the hood? My max has 35k miles.
ONe more question. What is a good oil filter to get for our cars?? And the oil filter number.
timing belts are covered (by a timing cover, of course) and go between the crankshaft and camshaft to keep the valves opening in correct time.
serpentine belts/v belts go around the pulleys on the accessories of your engine, providing your power, a/c, steering, etc. they're also not generally covered by anything and is often mistaken for a "timing belt"
now that THAT lesson is over....
when the serpentine/v belt squeeks/screeches or whatever, it usually means it's just loose or wearing out (stretching) ... 35k miles is a little early for those to be going though. cold weather tends to make it happen much easier though. the only thing you can really do to fix the noise is adjust pulleys to counter the stretching... or just replace them.
and like stated the squeak cannot come from your Timing Chain.
Hondarydr
Dec 30, 2024 06:15 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
