oil pan ?gasket? leak
Old Nov 24, 2006 | 04:07 PM
maximaownsyou's Avatar
im almost 100% sure the minor oil leak i have is in the oil pan, i have had different people tell me different things.. is it held by a gasket or silicone? thanks
Old Nov 24, 2006 | 05:01 PM
P. Samson's Avatar
It's all RTV sealant. Are you talking about the steel (lower) oil pan or the upper alum. oil "pan". If you think it's a leak at the upper pan splitline with the block and you plan to remove the upper oil pan then that is not a job for the faint of heart. If you think that the leak is from the upper one then I suggest that you absolutely double check and are 100% sure that it isn't coming from above and running around the edge "simulating" a leak there. Or a crankshaft/drive pulley seal, front cover, a camshaft cover (they've been cracking) or even the oil cooler. Leaks on these engines at these RTV sealed joints are quite rare, although I had a leak on a Ford Duratec front cover because of a 1" long void in the RTV that I finally found (after initially being sure that it was the pan/block splitline) that I was able to fix by adding RTV externally to that spot.
Old Nov 25, 2006 | 06:45 AM
ok thanks, ill double check today.. we really cleaned off the area completely so we could get a definate answer as to where this is coming from. but thanks that helps a bunch
Old Nov 25, 2006 | 09:20 AM
vinny's Avatar
rtv sealant not a gasket
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
