question
Old Nov 25, 2006 | 09:49 AM
arthur glazier's Avatar
question
my sister has a 98 extera with a 3.3 liter v6 the same as the max or very simular. so my my question is does it have a timing chain or a belt.The dealer wanted to chang the timing belt because it has 90k miles on it. I have a 2k make and im 99% sure that it has a chain but i just wanted to make sure.
Old Nov 25, 2006 | 04:20 PM
Alex_V
the xterra has a VG33E, which has a timing belt. your max has a VQ30DE which has a timing chain.
You better get that belt changed soon. Its not too bad a job as long as you have to tools. I just did it on my max and its the same setup.
~Alex
Old Nov 25, 2006 | 07:54 PM
paesantom's Avatar
on my vg would it also be a timing belt... because i'm coming up on 90k myself..
Old Nov 25, 2006 | 10:19 PM
mrkanda's Avatar
Taking my Maxima to the Max!
Yes. All VGs have the timing belt. The recommended interval to change it is every 60k miles I'm pretty sure. It's actually the first job I did on my Max, because my water pump had gone bad and leaked all over my original timing belt. I think they also recommend that you change the water pump, thermostat, tensioner, main seal and front cams seals while you're in there in order to save time and money (from having to go back in later). Good luck!
-Mrkanda
Old Nov 26, 2006 | 03:41 PM
Maxima9750's Avatar
The Nissan Xterra didn't come out until the year 2000. Do you mean a 1998 Pathfinder? Those had the 3.3L V6.
Old Nov 27, 2006 | 05:59 AM
xterra
your correct its a 2003,my mistake.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
