CV Axle assembly
Old Nov 27, 2006 | 02:55 AM
rimaximaman's Avatar
CV Axle assembly
Well, after 128,000K on my 94 GXE, the drivers side rubber boot on the CV slip apart, I guess from old age, I picked up a re-manufactured one from Advance Auto for $65.00 after core-return. I will be installing it this week, the passenger side one looks & feels in great shape, to I will let it stay for now, a competent mechanic told me that it should not take longer than 1/2 hour if you know what your doing, anyone out there have replaced this part before?
Old Nov 27, 2006 | 06:19 AM
Greeny's Avatar
¯\(°_o)/¯
Well i hate to break the news to ya,but on automatics,the passenger side axle must be removed first before the driver side,then you need a long screwdriver or other suitable tool to knock the d-side shaft out from the passenger side hole..
Old Nov 27, 2006 | 06:33 AM
Greeny's Avatar
¯\(°_o)/¯
The rest of the info for removal of the cv shaft is in the repair sticky..
http://www1.autozone.com/servlet/UiB...rGuideYMMEYear
SIDE NOTE: Don't forget to drain the tranny fluid into a suitable container before you start the shaft removal...
Old Nov 27, 2006 | 09:05 AM
DanNY's Avatar
Ad·min·is·tra·tor
i'm going have to disagree here. you CAN pull just the DS axle out w/o pulling PS axle out. get a pry bar and pull it out of the tranny.
also make sure you have a socket big enough for the nut at the end of the axle.
Old Nov 27, 2006 | 09:12 AM
Black92GXE's Avatar
Boomer Sooner
IF the nut is the same as the rear - it should be a 31mm socket - I had to pull my drums to replace the shoes and had to rent a socket set from oreilly's.
Old Nov 27, 2006 | 10:19 AM
maximapitko's Avatar
The Bulgarian Guy
you don't have to remove the passanger side axle. Just the driver's side a good sharp pull and it'll snap right out. Make sure you drain your tranny before that though...
Old Nov 27, 2006 | 11:28 AM
Greeny's Avatar
¯\(°_o)/¯
Go check yur idiotzone sticky..
I was going by that anyhoo,i haven't had take one out of the wifey's car yet
Edit: I thought you were jeff..
Old Nov 27, 2006 | 12:07 PM
DanNY's Avatar
Ad·min·is·tra·tor
well autozone uses the FSM as their guide. i'm using hands on experience as the guide.
Old Nov 27, 2006 | 12:28 PM
Greeny's Avatar
¯\(°_o)/¯
Yeah,hands on is always better info imo,Good thing this thread came along though,i would have taken both sides out...
Old Nov 27, 2006 | 01:38 PM
Thanks for the input, but after looking at the sticky from Autozone, I think that I will have my mechanic install this CV assembly, looks way to time consuming since I have never done one before. Question: How long can you drive on with a broken rubber seal on the CV joint?
Old Nov 27, 2006 | 01:39 PM
Old Nov 27, 2006 | 01:45 PM
Greeny's Avatar
¯\(°_o)/¯
I have driven for thousands of miles with broken boots without problems,but eventually,water/dirt will destroy the cv joint and it will start to clunk around corners...
Old Nov 27, 2006 | 03:09 PM
ColombianMax's Avatar
I agree on the axle removal...no need to remove passenger to remove driver side. Dude if you got time and want to learn I'd suggest to do it yourself, plus it'd be cheaper and you get to bond with your vehicle Oh be sure to to inspect the axle seal (ugh) if it doesnt seem all torn or bent just leave it alone.
All tools you'd need would be:
Jack/jackstands
14mm
17mm x2
19mm
36mm (axle nut)
nice prybar (set preferable)
Pliers to pull cotter pin
Torch (optional)
Thats all I can think of tool-wise but that should pretty much cover what you'll need.
Old Nov 27, 2006 | 04:53 PM
Thanks for the advice.......my fellow brothers of the Maxima Community are AWESOME!!!
Old Nov 27, 2006 | 05:03 PM
Hell yes we are
Old Nov 27, 2006 | 05:25 PM
sublunary's Avatar
but your still going to take it to a mechanic aren't you
i think you should grab a beer and have at it because you'll never do it a second time until you do it the first time
Old Nov 27, 2006 | 05:32 PM
I have an appointment 12-04-06 to have it installed, If I am feeling brave, I'll tackle it before that date.......
Old Nov 27, 2006 | 06:01 PM
sublunary's Avatar
that's what the beer's for
Old Nov 27, 2006 | 07:54 PM
Gun5's Avatar
anyway to knock the pass side out im taking the tranny out already got the drivers side axle off.. or should I just slide th tranny to the driver side and get it out that way? theres only a inch or 2 of clearence though
Old Nov 28, 2006 | 08:56 AM
DanNY's Avatar
Ad·min·is·tra·tor
separate the pass side axle from the bearing carrier. once it's loose from THAT then the axle will slide out also.
there's 3 10mm bolts on it..then take a nice big hammer and spin the bearing side to work it out. total PITA.
Old Nov 28, 2006 | 01:50 PM
After reading these threads, I have come to the conclusion that God put ASE certified Mechanics on the beautiful planet earth just for these types of problems........that we non- ASE certified humanoids may encounter!!!
Old Nov 28, 2006 | 06:04 PM
Lotta shops claim to be ASE but its just experienced mechanics. Is that scary enough to get you to DIY?
Old Nov 28, 2006 | 06:31 PM
Greeny's Avatar
¯\(°_o)/¯
I am not ase certified,but you keep trying to get me to come up there and fix you're car..
Old Nov 28, 2006 | 09:34 PM
Gun5's Avatar
was looking cant find those damn bolts got the car up about a foot or so.. im just creepin under the ***** until i raise it a foot/half for the tranny install
Old Nov 29, 2006 | 07:45 PM
My Mechanic is awesome, ASE certified, used to work for Toyota, know he works for himself in his own shop, he will Keep my 94 GXE on the road for many more years to come.....he told me that the Max will run as long as I want it to....& then some!!!!
Old Nov 29, 2006 | 08:35 PM
damn lazy maxima owner
Old Nov 30, 2006 | 05:35 AM
khemraj1999's Avatar
not to hijack the post but..do u mean make a clicking noise when u make turns?
mine makes a clicking noise from the passenger's wheel area when i make left turns or most turns. Could i have a broken boot also?
Old Nov 30, 2006 | 05:44 AM
Greeny's Avatar
¯\(°_o)/¯
Yeah,sounds like you're passenger side cv joint is broken..
Old Nov 30, 2006 | 03:37 PM
would it harm anything if i continue driving it for a while until i get money to fix it.
Old Nov 30, 2006 | 03:49 PM
Greeny's Avatar
¯\(°_o)/¯
I should be fine for a while,it takes quite a while before a nissan cv joint completely fail...
I wouldn't do any honda civic challenges at the stoplight until it is fixed though..
Old Nov 30, 2006 | 07:08 PM
i usually pull off fast(heavy foot). I have one more college bill to pay off on tuesday then i'll save about 1000 dollars and spend it on replacing my shocks, cv joint and few minor engine issues...my car only does about 180miles a tank ..but thats a totally drifferent post eh.
Thanks all!
U Guys are the BEST BEST BEST !!!
Your help is really appreciated.
Old Dec 1, 2006 | 05:11 AM
thanks man, i'll take my time with it until i can fix it.
Khemraj.
James92SE
142
Jan 2, 2024 09:23 AM
RealityCheck
Oct 2, 2015 06:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
atriuum
Sep 28, 2015 01:19 PM
Noela
Sep 26, 2015 08:22 AM
